Cyanogen10 Android 4.2.2 Rom for RK3066 Devices(1 SEP 2013)
    Originally posted by mohsen View Post
    hi
    i download this rom and install it
    but after finish run in RKAndroidTool my tablet reset and after it i just see a black screen!!!
    i think my recovery is damaged! now i want to put a new recovery to my tablet but i dont know what should i do!!becouse after reset and black screen when i plug the usb cable into tablet and pc nothing happend.jut screen of tablet became on with a black screen.
    i try to put a new recovery by RKAndroidTool i just see no find device for upgrating!
    pls help ....
    (my device is cube u21gt rk3066)
    First read the istruktion on this tred http://forum.xda-developers.com/show....php?t=2108704
    Install the laters stockrom and see that all its working as normal befor start trying other roms / tricks!
    Hint : Use a stock kernel from You stock rom that works and the new CWM-recovery then You flashing the OMA rom or You get problems.
    You can not bricking a RK3066 only flash a frech stock rom and You is up and running.
    If You is messing it up very hard You can always do a masc rom flash.
    MK802IIIS/BT
      Just wondering if anyone can tell me if this will work on the archos 80 cobalt?
      It has the same Rockchip RK3066 in it
        Anyone get this to work on imito mx2?
        Sent from my Galaxy Nexus using Tapatalk
          not working E can't mount plz tel me how to flash any steps plz
          not working E can't mount erorr update plz tel me how to flash any steps plz
            how to find wifi modules
            dear friends I succesfully installed this rom on my smart tv mediacom with rk30board. But at the moment works only with ethernet and not with wifi! It's like the modules are not loaded into the firmware. But like a stupid I dont make a backup of original firmware and it's impossible find that on web. So is there a way to find the wifi modules for example open the mainboard?
            This my actual lsmod :
            0x00000000ftdi_sio 27639 0 - Live 0x00000000
            pl2303 10261 0 - Live 0x00000000
            cp210x 10127 0 - Live 0x00000000
            ntfs 179004 0 - Live 0x00000000
            nls_utf8 994 0 - Live 0x00000000
            md4 3331 0 - Live 0x00000000
            rtl8150 8583 0 - Live 0x00000000
            mcs7830 5077 0 - Live 0x00000000
            dm9601 5644 0 - Live 0x00000000
            isofs 21745 0 - Live 0x00000000
            udf 69647 0 - Live 0x00000000
            sr_mod 11600 0 - Live 0x00000000
            sg 20320 0 - Live 0x00000000
            cdrom 32348 1 sr_mod, Live 0x00000000
            cuse 4093 0 - Live 0x00000000
            crc_itu_t 1035 1 udf, Live 0x00000000
            hubenable_genio 501 0 [permanent], Live 0x00000000
            vpu_service 11791 0 - Live 0x00000000
            rk29_ipp 9541 0 - Live 0x00000000 (C)
            mali 101401 18 - Live 0x00000000
            ump 26008 19 mali, Live 0x00000000
            rk30xxnand_ko 347336 0 - Live 0x00000000
            u0_a39@android:/ $ lsmod
            cdc_acm 13288 0 - Live 0x00000000
            mali 101401 12 - Live 0x00000000
            ump 26008 21 mali, Live 0x00000000
            The other problem is that the ethernet dont make correct ip address... so I cant access to adb via ip. Why?
