Every time I try to turn off the device with my air mouse from the navigation bar it doesn't shut down but rather restarts.
I have to use the physical power button on the box itself to turn off the device and even that some times doesn't work. I have to try multiple times.
I tried with downloading shut down apps from play store but no solution. The box restarts instead of shutting down.
Anyone else having this problem? Any solution?
