It is smart to choice Android 7, because of future use. Does some support 4k, or is it just fake fact?
What IPTV box that support Kodi and Plex well? Rockship is not recommand?
I look for a IPTV box to stream IPTV KODI and PLEX. Some of the boxed looks that they are verry unstable and I can see some say Rockship is not working well together with Kodi. What box is recomanded, and what chip?
It is smart to choice Android 7, because of future use. Does some support 4k, or is it just fake fact?Tags: None
hmm.. will do some testing (gk : IPTV =1300 ch )
allwinner + perfect player (heard some good things about this player)
allwinner + kodi 17 + simple client
amlogic (s805/s802 ) + libreelec (7/9) + simple client
Intel PC with nvidia GPU + libreelec x86 + simple client
just waiting for the "playlist"
Cheers
So... 3 hours ago got my e-mail ( username / passw / playlist / pin ? )
I will test things...then edit this reply
the howto states to use a app called AppleHD... so I did as starting point ( allw h6 andr 7 / allw ) ( CPU max 4.7 )
So, most streams are SD up to HD ( 1080p )
this app seems to have a tablet based ui with sw rendering as default, with HW enabled it looks fine / EPG is present
two hours 1080p...stream looks stabile (quality 7) ( app says no info about audio )
loads 5800 ch
perfect player... is a updated version of applehd it seems
it has alot more rendering/buffer options ... incl HW+ ( CPU max 4.0 ) ( it has ads ) (allw h6)
no info about HD audio (quality 7 but less stabile stream ) EPG is slow
loads 3600 ch
libreelec Leila / simple client (amlogic s802 )
it feels a lot more TV based ui
rec / timers seem to present ( but do not work)
loads 3800 ch (quality 7.5 stabile ) colors are more soft
allw h8 andr 4.4 applehd..the colors look vivid
but the stream has a few "loops" looks like 1gb ram isn't enough?
qualty 6.5 (CPU max 3.2 )
loop seems too be caused by stream change "***_HD to *** ( non HD )
taking a HD stream with HD audio (for stability testing)
When it comes stabile stream nothing seems to beat a Intel atom / nvidia GPU 730
yesterday I tested the s805/libreelec 7
it was suprised as it played 1080p/5.1 6h with only a few seconds small loops
the GUI was a lot more user friendly with previews and popup EPG
Quality 8 stabile
I bought a xmltv subr... it loads really good in kodi/libreelec
but far less in apple/perfectplLast edited by mitchell4you; 22 June 2018, 08:05.
There are currently 2573 users online. 1 members and 2572 guests.
