Help me chosing right ROM for my H96 PCB..
    Good morning guys,
    I buyed last Christmas my Android box from Banggood, the Alfawise H96 Pro+ 3GBram 32GBrom at this link
    Attached below there're the PCB inside the box (the label on the PCB says "3G+32G+3977 / 20171014"), now I need to identify wich version of ROM can be installed on..
    Thanks for help
    EDIT: just reading at this link and see the right picture same as my PCB, I think I've got the CZ-S32-V2.2 ...is that right? wath kind of ROM can I install now?
    Next PCB with no name of the variant. I wouldn't flash any firmware - official or not, as it may brick the device.
    Name would be on the other side of the board - second picture. However here is only the date, when this variant was first manufactured - 2017-06-22.
    ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
      I can read on the PCB the correct date 2017-10-22 (not June)... then following this page I can assume it's a CZ-S32-V2.2 version (same picture, same "maybe" electronics components).
      In this case of CZ-S32-V2.2 what ROM can I try to flash?
      Is there any information I can read from Android INFO page?
        True, it looks same. So if it is 2.2 than You should be able to flash superceleorn's roms or one of this official: https://mega.nz/#F!8qhRRaYJ!2ZA3VLjv...TF27g!Z6gTFC7A
          Ok, thanks for suggest as I think the same too...
          BTW I'd like some more information about ROMS.. (I'm a newbie with this device, but not for smartphones)... the link you give me are the officially ones, so I can take the newer and have a backup.
          About superceleron's rom, can you you suggest me one for download (Android TV version too?)??? There're many versions in this forum.. I cannot understand how can I select the right one (SCV1 - SCV4A - SCV7A - AndroidTV....)
            There are only two roms for H96 Pro+ worth mentioning, rest is for H96 Pro Dongle or older versions of superceleron's based on Android 6.0.
            Here You have links for 7.1.2 based SC roms for H96 Pro+:
            ATV: http://freaktab.com/forum/tv-player-...roidtv-version
            Normal: http://freaktab.com/forum/tv-player-...7-wifi-chipset
            Difference is in base - Android TV has it's own launcher which is hard to replace, where Normal version works same as on phone or tablet. And coz of base there is different apps in Play Store - You won't find ATV ones in Normal store and some Normal won't be available in ATV store. That doesn't mean they won't work, but You will have to get and .apk file and manually install them (here Apk Mirror is Your friend). As of today, there is more apps worth using not supporting ATV rom, than the one supporting it. I believe that there are two useful apps - YouTube and Netflix (which doesn't work on this Box), so for me Normal rom was better choice as I have to only manually update the YT app and with ATV rom there probably would be more apps I use that I couldn't find in Play Store.
              Thanks for your help..
                Hello, I have blue board S32-V5 (LPDDR3) 2017-08-29. 3/32gb version
                Thanks.
                Odoslan? z Redmi Note 4X pomocou Tapatalku
                  Which firmware do you currently have?
                    I have stock 7.1.2 rom
                      Yes...go into app drawer/settings/about. Confirm your firmware date.
                        This?
                          Yes.
                          I picked up several boxes Cz-S32-V5 (LPDDR3). They had firmware 20180607, just making sure..yours was not newer.
                          1. Fairly O.K.
                          aml_7.1.2_s912_q9377-S912_LP_mac-20180409.7z
                          https://mega.nz/#F!8qhRRaYJ!2ZA3VLjv...TF27g?U2IGDCIL
                          2. Mostly Good (krypton 4k was very smooth)..not sure if ATV launcher? (Version(20180607?) I'm using, not locked to ATV launcher)
                          aml_7.1_s912_q201_q9377_H96PROPLUS_LP-mac-20180706
                          https://mega.nz/#!CHwjSKDJ!eNrtpQ3Hp...e6FEDkbeyAN-K4
                          3. Untested..but newest.
                          aml_7.1_s912_q201_9377_H96PROPLUS_KDMC_LP_mac_2018 0824
                          https://drive.google.com/drive/mobil...OahCbRP1nmNxWB
                          Just to note, there is always a chance to brick your device.
                            Thanks for help ......I will try it.
                              Hi ,
                              what about the Rom of Superceleron , to be sure you can ask in his
                              Thread for compability , you can find it here on FT ,
                              greetings / gefattern
