I can replicate the issue at will this way:
1) Open pocket plays (client to watch streams on twitch)
2) start watching fullscreen (no chat, dunnno if it matters)
It will work for a bit and then disconnect, then it reconnects and after precisely 10 minutes it disconnects again and so on, after some disconnects pocketplays will just stop resume playing and from that moment I don't get any more disconnections.
I am on scv7 freshly installed, I had the same issue on stock also.
In the logcat I found nothing that seems to indicate an issue, but I'm new at this.
I get this when it disconnects
wpa_supplicant: wlan0: WPA: Group rekeying completed with e0:28:6d:router [GTK=TKIP]
wpa_supplicant: wlan0: CTRL-EVENT-DISCONNECTED bssid=e0:28:6d:router reason=3 locally_generated=1
I'm attaching the logcat in case someone is willing to help, I edited out my router's mac
