I'm trying to do something better with my TV Box. It's a polish TV Box from company called WIWA. Frankly, it seems like a copy-paste of many MeCool devices. At least the default interface seems to be the same, only with changed logo. You can see some details of this device here, on official website: http://www.wiwa.info.pl/produkty/dre...am-player.html
CPU: Amlogic S905X, Quad Code ARM® Cortex™ A53 Quad Core x CPU @2.0 GHz
GPU: Quad Core Mail-450@750MHz
RAM: 2GB DDR III
ROM: 8GB
Bluetooth: 4.0
WiFi: 802.11 a/b/g/n/ac, dual band 2.4 GHz/ 5 GHz
LAN: RJ-45
I am able to boot LibreElec / CoreElec with "gxl_p212_2g.dtb" file from microSD card on it. I don't have to press Reset button, it boots automatically, it seems that microSD has a higher priority over internal storage in bootloader. I guess that's as much info I can provide about this device.
I was thinking if it's possible to install Android TV ROM on it, either on microSD or internal memory. Do you think that one of the ROMs for MeCool devices could work or is it a road to bricking this device? Can I somehow dump my current firmware from it, so I can restore it later on?
