Alfawise H96 pro+ games Keymapping
    Hello everybody,
    I have tried to play with my joystick some games like ( PES 18 or pubg or dreamleague...) but not supported, i have to try to keymapping these games to controle them i have tried Tincore keymapper, Octopus, Gamekeyboard+, Gkm touch, .... all required rooted devices and i have rooted mine but nothing control those games.
    Please help me.
    My box is Alfawise h96 pro+ 3gb ram/64gb.
    My joystick is Tronsmart mars G02.
    Thanks.
    Most games support only chosen gamepads and Transmart may not be supported.
    Depending of You r Box PCB You may use one of superceleron's roms, which have better support for gamepads.
    ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
      Only few few games supports joysticks.
      My box alfawise h96 pro+ 64gb maybe its original Rom not that good for these kind of things like keymapping
        Hellosuperceleron
        Please can you help me or advice me.
        what should i do ?
        i will be thankful.
        Best regards,
          What was your problem with Tincore keymapper? Your controller was recognized? It works nicely with PS3 controller on original rom.
            Hello bernabap
            my controller is Tronsmart G02.
            its recognized by Tincore and i can set all the buttons and fully can be pushed.
            But working on games like PES 18 and many games.
            I have tried many apps like Tincore all recognize my controller but nothing works.
              I saw some videos how PES18 is played and I don't think you will be able to use a controller, it has to many swipe controls mid game. Even using the virtual pad option you will still need to swipe on screen, like the goalkeeper, and the direction that you swipe is the direction that the ball will follow. These are vary hard to emulate with gamepad.
                no its easy just need to make tincore takes control my android tv box with touch screen or click.
                  OK. I just downloaded PES18 and indeed the tincore_mt doesn't work with this game, I got some response using the Dpad as "Touch area reenter" anyway still not usable for me. But, with PS3 controllers we have the option to use the sixaxis_touchscreen in "DEVICES: TOUCHSCREEN/touch output device", which works with this game and have worked in all games/apps I have tried. I am using full version of Tincore.
                    bernabap Woooow it works for you amazing.
                    Can you please make a quick video explains what should i do please.
                    i will buy Tincore full version if it works for me.
                    i guess my joystick supports sixaxis.
                    Thanks a lot for you help.
                    and i subscribed to your channel
                      I have tried Dpad with "touch area reenter" but i can only move mouse cursor.
                        You need to pair your controller using sixaxis app, then use the sixaxis_touchscreen option in Tincore settings under "DEVICES: TOUCHSCREEN/touch output device", that's all.
                          Thanks a looooooooooot worked for me thank you so so so much for your help
