Hello everyone, I have a Pipo M9 Pro and I am having a problem with my Wifi being slow. I have other wireless devices that I have tested on the network and they have fast normal speed. My Laptop gets 50 Mbps download speed and my Samsung Galaxy S4 gets 45 Mbps download speed. My Pipo M9 Pro only gets 8 - 12 Mbps speed and only gets 960 KBps on file transfers.
The signal says it good. I have full bars and a strong -40 dBm signal, but my tablet is the only device on my wireless network that is getting slow speed.
I am using Riley Rom 1.3a and had this problem with the stock rom when I got the tablet. Is there anything I can do to fix this or do I have a bad Wifi chip?
I am suffering from the same problem. When I leave the living room, speed drops and big transfers like YouTube or app updates will cause my wifi connection to disappear. I wonder if I should RMA it.
