I've been using my H96 Pro Plus with SCV7A for many months. Now it's stuck in a TWRP reboot loop. I've used USB burning tool and reflashed an older factory firmware and then it reboot loops into Android stock recovery. I've also reflashed SCV4 (the precursor to 7A) and I receive the same TWRP boot loop. I'm positive I'm using the correct firmware as they have been archived on my hard drive since I initially flashed them. Also, when in TWRP I can mount and use the file manager to browse the System and Data partitions.
I searched and then tried a fix I found regarding dd'ing a zero file to the Misc partition, but it hasn't solved the loop problem either.
Is this box now a doorstop or are there alternate fixes I can try? Ideas? Thank You.
