MXQ PRO 4K not recognized. How come?
Originally posted by rawolph View Post
if you know you have the same Specs , yes , otherwise , was your Wifichip the 6051p or another ,
do you have a 1/8GB or 2/16GB Box ???
good luck / greetings / gefattern
Originally posted by rawolph View PostHi,
I flashed that firmware but things got even worse.
Please, help me find a firmware more appropriate for my device: 1/8GB Rk3229, sv6051p wifi chip. Thank you!
if you read the whole Thread , you will find some more Links , did yo tried one of them ???
Hi ,
Originally posted by rawolph View PostI don't know how but I was able to unbrick it by using the restore function of rkbatchtool. Now I have to understand which firmware I can flash.
when you flash a new RK Rom "eraseFlash""Nand" is always a must , otherwise
u can get "Errors" like discribed .
What was the latest Rom Version on your Box ???
Hi ,
I have to erase flash for every ROM I try or only when I downgrade (for example from Nougat to marshmallow)?
My latest ROM was based on Android Nougat but it was a mess like I said. Now I have the 7.1.2 ROM by spectek BUT it's too much laggy, the launcher often crashes...almost unusable. I really don't know which ROM to flash...
i really do not know which is the best Rom for your Box , i do not have a RK3229 Box ,
but if only the Launcher makes problem , why not dowloading & installing another from
PlayStore ??? ,
Originally posted by rawolph View PostI solved by flashing a ROM based on Android Nougat by Leelbox. Good performances, everything works except IR.
I will also try the custom Nougat ROM by mo123.
sounds good , IR support is not so important , for better usage , i , and many others , using a BT Mouse & Keyboard ,
or AirMouse , much better then the most , cheap and bad controllable IRs .
There are currently 973 users online. 5 members and 968 guests.
