Balight 2017 M8S PRO Android 7.1 TV BOX 3GB+16GB DDR4
    Hello all, I am a bit of a noob, so I wanted to ask you guys for recommendations
    I got this about a year ago, OTA updates are not working, and the box have been rebooting randomly lately.
    So I was looking to update the firmware for it manually.
    I am a bit lost on which firmware should I get.
    The box I had purchased back then is in the below link.
    Balight 2017 The latest M8S PRO Android 7.1 TV BOX 3GB+16GB DDR4 Amlogic S912 Octa-core ARM Cortex-A53 CPU up to 2 GHz Built in 2.4G/5G WiFi With Bluetooth 4.1+HS
    it says:
    Model: MS8 Pro
    Version: 7.1.1
    Kernel: 3.14.29 Fri May 5, 08:51:01 CST 2017
    Build: M8S Pro-userdebug 7.1.1 NMF26Q - 20170505.084815.v0222
    I see the M8S Pro L, but not sure if the firmwares for "L" will work with my current box. If anyone can guide me to the proper firmware I will be very grateful.
