After the battery level gets to just below or at mid level, it shortly there after drops to near nothing. I've tried some battery calibrators, but they didn't pan out.
Next8p12 Rom - MagicRom
Has anyone else experienced some strange behaviour with the battery level indicator. I'm currently giving this ROM a try, but I can't really remember if I experienced the same with shaunmt's stock build as well.
Recovery failing
Originally posted by magicone View Postmy first Rom: MagicRom
MagicRom ver. 1.1
ONLY Tablet: Mediacom 815i e Next8P12 (CHIP AMLOGIC 8726-M3)
change on 1.1: FIX ROOT - Remove img file for nextbook - Change bootanimation
Feature:
- Similary stock
- build.prop optimized
- Cpu Mode Setting
- HDMI SWITCH add 1080p
- Rooted
- Delete some app
- Deodexed
- Add old version of root explorer
Istruction:
1. - Download Recovery: Link unpack and copy on SD
2. - Download MagicRom: Link copy directly on SD
3. - Download GAPPS: Link copy directly on SD
- restart in recovery (power and vol+)
- Data factory and Wipe media partition,
- Install MagicRom
- Install gapps
- Restar Normally
NB: AIf has proble with Google Play then download and install Google Play 4.3.11 da qui: Link
NB2: For mediacom user "image of boot and image of loading changing with Next8P12"
Regards to me for ROOT, view post su androidiani.com , user of http://www.freaktab.com/ (ShaunMT) for stock Rom of Next8p12
Link XDA: http://forum.xda-developers.com
Link freak: http://www.freaktab.com/
I get to
"Verifying update package..."
E: failed to verify whole-file signature
E: signature verification failed
Installation aborted
same message no matter which I try...
Re: Next8p12 Rom - MagicRom
Originally posted by Valboski View PostI downloaded/unpacked recovery and copied to microsd card, downloaded/copied Magicrom and Gapps zip files to microsd card--none of the three will install.
I get to
Sent from my LG-P970 using Tapatalk
There are currently 2202 users online. 1 members and 2201 guests.
