flashing android 6.01 i can, but any version of 7.1.2 is just not working. I use the usb flash method. The box originally came with 7.1.2, but it got stuck, since then only 6.0.1 is working. I get, if i'm lucky, a flash of the second logo, then image is turned black and can only see the mouse cursor when i move it. Specs: 1gb/8gb mecool km8 p mediabox. Though in android 6.0.1 neither 4k nor hdr is working.
mecool km8 p update to 7.1.2 not working
Hello all,
flashing android 6.01 i can, but any version of 7.1.2 is just not working. I use the usb flash method. The box originally came with 7.1.2, but it got stuck, since then only 6.0.1 is working. I get, if i'm lucky, a flash of the second logo, then image is turned black and can only see the mouse cursor when i move it. Specs: 1gb/8gb mecool km8 p mediabox. Though in android 6.0.1 neither 4k nor hdr is working.Tags: None
it was more easy then i thought. First installed 6.0.1. Booted it up and inserted sd card. Then formatted sd card as portable. Then put km8 p 7.1.2 ota fles on sdcard. Insert it again in mediabox. Go to android update and choose zip file from sd card and let it update. So now again, finally, 7.1.2 on the mediabox.
Ok, i've found a working img from another brand q201. The Vorke z6. Flashed it and it booted. Now everything seems to be working, but the lan. When i go to system info page, settings and about box, network info, it says thee macc address of the wifi, but for lan it isn't mentioned. The systtem does report when i insert a cable, when a cable is connected. DHCP doesn't work, neither manual inputting the addresses. How to get the lan port back in function?
The Vorke z6 rom, compatible with km8 p 1gb 8gb(recovery neither lan working): https://1drv.ms/f/s!ApsAD6QmyMvBhmVgFVFWtIZtFb7yLast edited by mark-1978; 24 June 2018, 11:04.
managed to update to poisonrom 4.1. First installed nano img through boot card maker. Then installed poison 3 beta rom through twrp recovery. Twrp took a bit of time at the booting after holding the reset button. But it worked.
First boot: boot logo, followed by bootanimation, v4.1 freezes in bootanimation, v3b gets black screen, as it should, but longer then 6 minutes.
ow: nexus img: http://freaktab.com/forum/tv-player-...om-android-7-1
poison3 beta (downloads section): https://forum.xda-developers.com/and...n-rom-t3751720
NOT WORKING on km8p 1gb/8gb.Last edited by mark-1978; 30 June 2018, 17:44.
There are currently 1789 users online. 0 members and 1789 guests.
