Product link: https://bit.ly/2JFk0HZ
Intel Core i5-7200U
The Intel Core i5-7200U, developed under the codename Kabylake-U, is an embedded dual-core processor, results in a great multi-tasking potential.
This Core i5 series CPU operates at a stock clock speed of 2.50 GHz. If that isn't enough power, the Core i5-7200U has been tested to handle a maximum overclocked speed up to 3.10 GHz.
Operating System of Your Choice
Moreover, you can also use the OS of your choice, from Linux distributions to Windows 10, Chrome OS, whatever does the job, besides the preinstalled Ubuntu16.04.
8GB RAM, 128GB SSD
It boasts 8GB RAM, 128GB SSD storage, advantageous in performance, security and reliability, ascribing to the eMMC memory, ultimately delivering a richer end-user experience.
IEEE 802.11ac
IEEE 802.11ac, one of the wireless networking standards in 802.11 family, is developed in the IEEE Standards Association process for the purpose of high-throughput wireless local area networks (WLANs) on the 5 GHz band.
Gigabit LAN
Gigabit LAN provides a data rate of 1 billion bits per second.
Other Features
Ultra compact PC design at only 0.6L (39 x 124 x 129mm)
Supports 2.5" HDD/SSD, 7.0/9.5 mm thick (1 x 6 Gbps SATA 3)
VESA mounting Bracket (75 x 75mm + 100 x 100mm)
Applications
Office Work: Office, skype, yahoo, outlook and all other office requirement support and runs perfectly.
Design Work: Photoshop, CoreIDRAW, Dreamweaver, IIIustrator, Flash, Indesign and others.
Game Playing: Support most of the online games and PC games, like Warcraft, Counter-Strike (CS), support 3D games.
Entertainment: Support 4k video play, XBMC and others.
