VORKE V2 Pro
    VORKE V2 Pro
    VORKE V2 Pro Intel Kaby Lake R i5-8250U 8GB DDR4 RAM 128GB SATA SSD Ubuntu 16.04 Mini PC AC WIFI Gigabit LAN HDMI USB 3.0 TYPE-C Upgradeable to 16GB
    Product link: https://bit.ly/2JEiAgH
    Coupon for VORKE V2 Pro: BWISCVXY , final price: $395.99
    Intel 8th Gen Core i5-8250U
    The Intel 8th Gen Core i5-8250U, developed under the codename Kaby Lake R, is an embedded Quad-core processor, results in a higher multi-tasking potential when compared to processors with more cores.
    This Core i5 series CPU operates at a stock clock speed of 1.60 GHz, the Core i5-8250U has been tested to handle a maximum overclocked speed up to 3.4 GHz. Its cache size is 6 MB SmartCache,
    Operating System of Your Choice
    Moreover, you can also use the OS of your choice, from Linux distributions to Windows 10, Chrome OS, whatever does the job, besides the preinstalled Ubuntu16.04.
    DDR4 8GB RAM, 128GB SATA SSD,
    It boasts DDR4 8GB RAM, 128GB SATA SSD, advantageous in performance, security and reliability.
    IEEE 802.11ac
    IEEE 802.11ac, one of the wireless networking standards in 802.11 family, is developed in the IEEE Standards Association process for the purpose of high-throughput wireless local area networks (WLANs) on the 5 GHz band.
    Gigabit LAN
    Gigabit LAN provides a data rate of 1 billion bits per second.
    Other Features
    Ultra compact PC design at only 0.6L (39 x 124 x 129mm)
    Supports 2.5" HDD/SSD, 7.0/9.5 mm thick (1 x 6 Gbps SATA 3)
    VESA mounting Bracket (75 x 75mm + 100 x 100mm)
    Applications
    Office Work: Office, skype, yahoo, outlook and all other office requirement support and runs perfectly.
    Design Work: Photoshop, CoreIDRAW, Dreamweaver, IIIustrator, Flash, Indesign and others.
    Game Playing: Support most of the online games and PC games, like Warcraft, Counter-Strike (CS), support 3D games.
    Entertainment: Support 4k video play, XBMC and others.
