Many thanks!
Root
So You already have TWRP. Now You need this: https://forum.xda-developers.com/app...mless-t3473445
Or this (it's beta of the above one): https://forum.xda-developers.com/app...80cb6-t3618589
Both works fine.
Than You have to use update app (if it works for You, coz for some people it doesn't) to flash the .zip.
Or just boot to TWRP: turn off the Box, disconnect power cord, start pushing reset button, connect power, keep pushing for 5 seconds or more.
It should boot TWRP where You should go to "Install". There is limited File Manager which You need to use to look for downloaded .zip, choose it and swipe to start Flashing. After it finishes reboot the device and You will have rooted firmware.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
There are currently 1287 users online. 1 members and 1286 guests.
