I have a bricked box and after searching and downloading and trying and not getting any image to work, I try to see if anyone out there can help me out to better identify this box and/or point me to a image that works.
The info I have:
From the Outside Box
OTT TV BOX Action 4K AS-14 64bit
4x CPU Cortex A53 5X GPU Mali-450
2GB RAM
16GB ROM
From Inside the Box
S905_V03 2016.04.15
M8_IO V3_0_20150110
AP6330
I have been searching for firmware for the M8 S905 but it seems hard to find and most results are all about M8S or MXQ and similar.
I'm using the USB Burning tool.
I hope someone out there might point me to a better direction.
Thank you all for your time.
