[ROM] Stock H96 Max 7.1.2 firmware 20180525
    This is definitely a good rom, youtube 4k HDR, dolby atmos with spmc, works fine with sony A1.
    Hope there will be a custom one for this 0525 rom
      Which Flashing tool did You use ...
      I flash it over SCV1 Rom and It just hangs ...
      Have You flashed SCV1 Rom before ?
      Michael T.
      3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
      CVSB-K200-Wireless Mini QWERTY Keyboard / Motion Mouse for Android RF
      Rii Mini i25 Qwerty Keyboard/Motion Mouse For Android RF
      Media Flow Suite ... 24 TB ReadyNas Pro wired 1 GB Ethernet
        Well, gonna try this on my H96 Max rk3399.
          Am currently installing it using Driver Assistant v4.5 installed as Administrator and FactoryTool-v1.45e also installed as administrator. And Success .i'm at the Aplication Installation screen.
            do you know if it's suitable for both 6255 and 9377 WiFi modules ?
              Well, eversince i installed this version on my box , whenever i play a movie on the latest FTMC player the app suddendly stops after half an hour of playing and then its fastforwarding by itself and the audio dissapears. Its been happened two times in one movie already. Only restarting the box brings everything back to normal until the happenings occur again , and they will occur again.
                do you have FTMC installed as a system app
                  No, how do you install it as a system app ?
                    you can use for example Titanium Backup to do that
                      So yeah, after installing FTMC as a system app using es file explorer with root explorer the app will just crash at opening it. Therefore, i shall go back to the update that was released on the first week of May of this year. That one worked better with my box.
                        Regarding the 20180502 firmware, they removed the Main Menu Display option (COLOR, which allowed the 10bit ycbcr444 configuration), which dramatically improves the image. Returning to 20180502. http://geekbuying.mediafire.com/file...9_20180502.rar
                          I agree. The 20180502 firmware is better. Works deffinetly better with my box. Movies dont have that lag anymore followed by the loss of audio that can only be fixed by restarting the box.
