New Mecool M8S Pro L (LB) with normal remote (no BT voice) firmware needed
Originally posted by tigasaeng View Postdo someone has a new firmware compatible to Mecool M8S_(LB) PRO_L-NHG47L-20180316.115110.V0213? with no issues, i want to update my device to stock img rom ATV version. if their is please give me a copy. thank you
Originally posted by Giannis View Post
Read my #1 post carefully. For now there isn't any other (stock or custom) firmware available with ATV firmware available for LB boxes with normal remote (no BT version). The other two V.0213 ATV firmware's is for LB boxes with BT voice remote and aren't compatible with your box.
Originally posted by supermal View Post
There is only one stock firmware for LB version boxes.so it must be compatible.the fact that you are having issues with your box may be due to hardware defects on your box.firmware should be ok for other users.
No. There are two different stock firmware's for LB boxes:
1. 20180316.115110.V0213 stock rom for LB boxes with normal remote, ATV version and with mecool leanback launcher. (no ota update yet) -[It's my box]
2. 20180316.143701.V0213 stock rom for LB boxes with BT voice remote, ATV version with android tv leanback launcher (ota update 20180417.150752.V0213)
I agree with you. Both of stock roms might be compatible with LB boxes (as same ver. 0213) independently if they came with normal or BT voice remote. But unfortunately this don't happen.
The same issues as post #1 with me, had and a friend of mine with same box, when he tried to flash the 20180316.143701.V0213 stock ATV rom. (Finally he recovered his box with mine twrp backup of stock rom 20180316.115110.V0213).
I don't know if it happens the opposite because I haven't the BT version to test it. ( if someone with LB box with BT voice remote try to flash the 20180316.115110.V0213 stock rom will have similar issues?).Last edited by Giannis; 29 August 2018, 21:07.
1. 20180316.115110.V0213 stock rom for LB boxes with normal remote, no ATV version and with mecool launcher. (no ota update yet) -[It's my box]
2. 20180316.143701.V0213 stock rom for LB boxes with BT voice remote, ATV version (ota update 20180417.150752.V0213)
I don't know if it happens the opposite because I haven't the BT version to test it. ( if someone with LB box with BT voice remote try to flash the 20180316.115110.V0213 stock rom will have similar issues?).Last edited by supermal; 20 August 2018, 08:50.
Thank you for explaining things a bit clearer for me.l have LB box with bt voice remote.i may be wrong here but I think you must use the matching remote for whichever firmware you install on the box.otherwise it seems to result in issues.dont know why mecool have made things so confusing for owners.i was annoyed to receive a LB variant after I had done my research and ordered box not knowing they changed the wi-fi module without making it known.could you give me a link to the firmware on your box I might try it.
Additionally I think its a "big foul" to the futured owners the change without warning of the wifi-BT chipset to Broadcom 4335, so we cant use any custom rom without losing the wifi-BT functionality.
Now about my stock rom. Because of the lack of support firmwares for mecool boxes, there is nowhere in the net (until now) the img 20180316.115110.V0213 stock rom. But in the following link is a full twrp backup from the original 20180316.115110.V0213 firmware, so if you want to try it you can flash it via twrp recovery (restore).
https://www.dropbox.com/s/67ogptuag8...ackup.zip?dl=0Last edited by Giannis; 21 August 2018, 09:54.
Hi supermall. I believe mecool / videostrong, for some unknown reason,don't want owners of different versions of LB boxes (normal - BT voice remote) use other stock rom versions (with mecool launcher or leanback launcher) than the boxes had factory flashed, make them "some way" no compatible, even same ver. 0213.
https://cavutw.bn.files.1drv.com/y4m4xFtbDXZu0VlNA3GdxPYNWBXf5Fapnv0LpWoO97Z9 here is a zip file i believe is the original stock rom for non android tv version with normal remote.try it at your own risk or check before using.hope it helps.
Originally posted by supermal View Posthttps://cavutw.bn.files.1drv.com/y4m4xFtbDXZu0VlNA3GdxPYNWBXf5Fapnv0LpWoO97Z9 here is a zip file i believe is the original stock rom for non android tv version with normal remote.try it at your own risk or check before using.hope it helps.
http://blog.geekbuying.com/2018/08/m...date-20180316/
For now I use my stock rom 20180316.115110.V0213 with some changes according my personal preferences:
a. Change the Launcher. Installed NOVA launcher apk and at the same time I removed (with root uninstaller apk) the mecool leanback launcher and the leanback recommendations apks, because I didn't like the light white mecool launcher and I prefer an "android feeling with icons" . Additionally I added (via nova apk settings) two shortcuts to the main screen, for recent applications and for notification bar, for easy access.
b. Uninstall possible bitcoin miners / "suspicious" system apks with no obvious use. I uninstalled, with root uninstaller apk, the following six suspicious system apk from stock rom: BCenter, BMgmt, BService, BUpdate, TCBBOOT, Mgmtsupport. After the uninstallation of these apks the behavior of the box has an overall improvement. ( More responsiveness and fast, better performance in 3d games, "zero" wifi - bt disconnects, lower cpu load in idle and finally the android tv youtube apk freezes issues suddenly disappeared).
c..Uninstall other system apks useless for me (like "tv center" , installing latest kodi version).
After these changes I made a twrp backup, of this stable state of the rom, for use to recover in the future.
Originally posted by Giannis View PostHi stants and SnowLeopard.
In the following DropBox link is a full twrp backup from the original20180316.115110.V0213 Mecool M8s Pro L (LB) firmware (LB boxes with normal remote). You can flash it via twrp recovery (restore).https://www.dropbox.com/s/4pjfmzzckv...V0213.zip?dl=0
Tell me if it works.
Hello Friend, Can you re-archive this file as it is no longer available?
Originally posted by rapht1 View Post
Please,
In the following link is a full twrp backup from the original rom. Try flash it via twrp recovery (restore). (Download it - unzip - put the folder in a stick or sd card - boot to twrp recovery - select restore).
Hi rapht1.
My box is the LB version, I installed the stock rom TV, however, as everyone said, wi-fi and BT stopped working.
I came back to this version and everything was ok.
Will one day we have to rom the TV to our LB box?
There are currently 2434 users online. 2 members and 2432 guests.
