Help me find the pins to short
    Hi all,
    I have a MXQ pro 4k with rk3229. A friend of mine suggested me to flash an ATV custom rom. Result? My tv box got bricked: red light, no boot (black screen) and RKbatchtool can't detect it. I suppose I need to short the magical pins. Am I right?
    Could you please help me understand where are these pins on my board?
    Thanks in advance.
    Originally posted by rawolph View Post
    Hi all,
    Thanks in advance.
    Hi ,
    the Pins you normal have to short for RK , are on the Nand , most
    Pin 7-8 , i believe , what about a Picture of the back ,
    greetings / gefattern
      Hi ,
      here is the back: https://imgur.com/a/AYPoK0R
        Hi ,
        looks like the Nand is on back , (the bigger one on the edge) ,
        and the pins for short on the front , you can see the solder strips
        from the Nand , directly on top of Nand (otherSide) , look for small
        triangle on Corner , from there start telling , i think you must use the
        inner solder stripes , try them and report ,
        good luck / greetings / gefattern
          Hi ,
          Ok, I was able to unbrick it by bridging pins 8 and 9 on the right side looking the front of the board: https://imgur.com/a/4a648ik
          Then I restored it using RKBatchTool and flashing as usual.
          Thanks for your help.
          Hope it will be useful for someone else with the same PCB.
          • gefattern
            gefattern commented
            Editing a comment
            Hi , sound nice , much Fun with your Box , grettings / gefattern
          Hello I have RK3228 in my smart box, is the same pins shortcut like RK3229??
            Hi ,
            normal well , try , nothing bad can happen , if you follow or already know the steps to unbrick ,
              Hi ,
              Hello, could you help me?
              Here are a 2 pics... I have the same problem and nothing is working, just a black screen... which pins and where? Could you circuit it or just give a good def because I'm more of a visual person, sorry.
                All i see is a circle by the big black rectangle in the first picture
                  Hi ,
                  first your Pictures are not good , but as i can see in Pic. Nr.1 , the Chip below the
                  Heatsink is the Nand , like above discribed in the Posts ,
                  first , install RK Drivers , load FW to Flashtool ,
                  second , connect only USB to PC & PCB ,
                  third , short Pins , like discribed , plug in Power ,
                  wait till Sound , or , & Tool shows " MaskRomMode" ,
                  restore your Box , wait till ready , close Tool , wait a few minutes after flash ,
                  about 5-7 min , unplug , power off , connect to Tv & enjoy your Box ,
                  hopefully , for more Info , search on big G for :
                  reflashing in MASKROM mode for Rockchip devices , use the Ugoos Site or
                  any other ,
                  good luck / gefattern
                    Hi ,
                    any other ,
                    Thank you for your help, I will be trying this when I get home today. Why don't you make youtube videos about these devices? You are very good and even your text descriptions are in detail!
                    Thanks, Arise.
                      Hi ,
                      any other ,
                      Nevermind, got it all working, just the firmware that I need to find now, turns out the screwdriver that I used didnt do anything with the pins etc. so I used a needle and it worked on pins 1-2 bottom right! ! !
                      Im getting frustrated now /;
                      I really don't know how to short ! !
                      So what I did was, install the drivers, load the firmware, plug the usb in the pc connected to the android box, i then took my tweezer and did the bottom right pins 7-8 and plugged in power... nothing happens.. is there a video I can watch? I'm so bad at this sorry...
                      Thanks,
                      Arise
                        Hey, what firmware did you use?
                          Hi ,
                          what Windows do u use ??? first , no screwdriver , a small needle or cupper wire shall do the Job ,
                          if you do it like discribed it must work , Videos exist on Youtube , hope you will get it working , to
                          restore , you best can use the Stockrom , hope you have it , please use latest Drivers 4.5 & you can
                          use Androidtool 2.35 & above , for flashing , Factorytool 1.5/... 6 , is good for flashing too ,
                            Hi ,
                            Hello, I got it working with the pins its just the firmware that I need to get...
                            I've tried the stock firmware from the http://mxqproject.com/files/Rockchip...ecovery-Tools/ thing... i downloaded both firmwares and non of them worked... I don't know where to get the firmware as I bought it from a store and not online... so there is no way to contact the original seller...
                            Thanks, Arise
