Help With Bricked Box(Z9 PRO 4K)
    Hi Guys need some help with this broken box. It is a Z9 PRO 4K android tv box. The problem is when it start up the Z9 Pro log come on screen the the android man come on and sticks. I have added some photos to give you an idea. The third pick is of another Z9 Pro info. Hope you guys can help. Thanks
    BOXFIX91
    Hi Guys i got the box to be recognized by the USB burning too but have an error at 8% [0x30402004]UBOOT/Partition boot/Initialize partition/Error result.
    BOXFIX91
      Hi ,
      do u use the right Rom ???
      greetings / gefattern
        Hi ,
        Hi Gefattern,
        Thanks for replying. Unfortunately i am not sure if i have the right Rom. Can you assist me with this?
        I will attached the board and the realtek chip. Your assistance is much appreciated.
ID:	733692Click image for larger version
        BOXFIX91
          Hi Gefattern,
          Hi ,
          first , please carefully take of the Heatsink , not only that we can see the CPU ,
          because he is totally wrong placed , the Heatsink can be taken off with the help
          off a Hairdryer , but not to close , because off Heat , but not to close .
          Then clean the rest carefully , so you can place the Heatsink back later , to the
          right place .
          I think it is a S905 Box , maybe we can find a good working Rom for your Box , but
          i am more a RK Man , but for flashing / restoring your Box the StockRom is better ,
          do you have a working one ??? Please give the full Filename , thanks ,
          be patient , with Panic and Stress a Box will be not restored so well as relaxed .
            Hi Gefattern,
            i have removed the heatsink and see the attached cpu. Click image for larger version  Name:	Z9PRoCPUimage00001.jpg Views:	1 Size:	81.8 KB ID:	733863
            I do not have a stock Rom and the ones i have tried do not go pass the 8%[0x30402004]UBOOT/Partition boot/Initialize partition/Error result.
            I have tried hugsun_s905_mxq_20160509 & 20160527. i have also tried amologic-s905-mxq-ota-20160331.
            BOXFIX91
              Hi ,
              now u can glue the Heatsink back to his right Place , do we must
              search for a Rom that supports the 8189 Wifichip , i think u can
              try the Rom from Coolio for S905 , maybe it fits :
              http://freaktab.com/forum/tv-player-...-atv-by-coolio
              there is for sure a working Rom we only have to find it , but your
              Box is a 2/16GB Box or a 1/8GB Box ??? This Rom is , i think ,
              for 2/16GB Boxes ,
              good luck / gefattern
                Hi ,
                for 2/16GB Boxes ,
                Hi Gefattern,
                What can i use to stick the heatsink back on?
                The box is a 1/8GB.
                Will search for rom, but if you find one you can also send it to me.
                thanks.
                BOXFIX91
                  Hi Gefattern,
                  The box is a 1/8GB.
                  thanks.
                  Hi ,
                  best you sell a small "syringe cpu paste" to place it back , not more
                  then 10€ , but then u have it for sure good placed and the CPU can
                  better be cooled , u can ask in this linked Rom Thread if it works for
                  a 1/8 Box , i dont know , here is another one :
                  https://androidtvbox.eu/new-firmware...70116-release/
                  u can try this one , hope it works , good luck / gefattern
                    Hi Gefattern,
                    The last link you sent server seem to be down.
                    Can you tell me how the heatsink should be place on CPU?
                    Thanks.
                    BOXFIX91
                      Hi Gefattern,
                      Thanks.
                      Hi ,
                      just place it in the middle , not like before , u can find
                      several Pictures here & from Tv Boxes on YT .
                        Hi ,
                        i was not sure but it looks like Coolios Rom is for 1GB Boxes ,
                        so u can try it for sure ,
