Blackview P10000 Pro 5.99 Inch Smartphone MT6763 4GB 64GB 16.0MP+0.3MP Dual Rear Cameras Android 7.1 OS (Android 8 coming soon)11000mAh Battery
Hi People,
The Blackview P10000 Pro is the next new device from Blackview Packing a huge 11000Mah Battery,Yes you read this right a Whopping 11000Mah Battery that will give the average user up to 5 days of use with ease.
The Blackview P10000 has 3 available options, Mirror Silver or Mirror Grey with a glass panel, or Leather Gray with a leather back panel. Reguarding the build quality this feels like a top end phone very well made from what i can see and it comes in at reasonable price.
On opening the box the Blackview P10000 Pro it comes with a screen protector pre-installed,A AC adapter of the standard 2 pin type 5V 5amp,A Type-C to USB charging cable that’s much thicker than the usual (For what i guess is for the higher amperage of the charging used for this phone) A user manual,A SIM tool for ejecting the SIM tray. There's also a USB Type-C to 3.5mm headphone adapter as this device doesn’t have a headphone jack itself,There's some headphones too,Also a USB Type-C to USB adapter is included, A protective PU soft case and a 2nd screen protector.
Highlights (From webpage)
Blackview P10000 Pro 4G Phablet 6.0 inch Android 7.1 MTK6763 Octa Core 2.0GHz 4GB RAM 64GB ROM Quad Cameras Type-C Glass Back Case 11000mAh Battery
Display: 6.0 inch 2160 x 1080 pixels IPS screen
CPU: MTK6763 Octa Core 2.0GHz
System: Android 7.1
Storage: 4GB RAM + 64GB ROM
Cameras: 16.0MP + 0.3MP dual back cameras and 13.0MP + 0.3MP dual front cameras
Sensors: Gravity Sensor, Gyroscope, Geomagnetic Sensor, Proximity Sensor
Features: GPS, Glonass
Bluetooth: 4.1
SIM Card: dual SIM dual standby, 2 x Nano SIM card and a TF card can be inserted at the same time
Networks:
2G: GSM 850/900/1800/1900MHz
3G: WCDMA 900/2100MHz
4G: FDD-LTE B1/B3/B7/B8/B20
About Blackview
Chinese manufacturer Blackview has slowly been building a reputation in the rugged smartphone market.
BLACKVIEW was founded in March 2013 by serial entrepreneur Xu Ming(David Xu) , who believes that high-quality technology doesn't need to cost a fortune. Blackview brand is owned by Shenzhen Doke Electronic Co., Ltd.
BLACKVIEW advocates "quality and experience", imposing strict examination on each procedure from design to production. In terms of quality, all products of BLACKVIEW are subject to strict high standards and high-quality testing processes to ensure that every user has perfect experience.
Looks and feel
The phone itself has metal sides with rubberised plastic on the top and bottom. The phone has a nice feel to it, On the edges of the phone you will find nice curved corners, as well as the usual buttons and inputs..Comes pre installed with Android 7.1 & with the promise of Android 8 soon.
The P10000 Pro is certainly not lightest device on the market, weighing 290 grams and measuring 165mm x 77mm x 14.7mm.The weight of the P10000 is mainly down to massive 11000mah battery and the phones 6" Sharp-built screen full HD+ display that has a ratio of 18:9 and a resolution of 2160 x 1080.
Home Screen
App Draw
Front
Left hand side
Is the SIM and SD Card slot
Bottom
Is what looks like twin speakers (But only one works)And the Type C charging point
Right hand side
Is the Volume rocker and the power button
Rear
Is the twin camera the the dual LED light
PU case
Its great to see it come with a rubber case so your ready to go from day one
Some Tech Stuff
Iv never had a phone see so many Wi-Fi networks
GPS
Camera (Sony cameras)
On the rear of the P10000 is the twin camera,A 16 megapixel and 0.3 megapixel with a f/2.0 aperture and a two tone LED flash light. The front facing camera is another twin setup with a 13 megapixel and a 0.3megapixel camera.
Some camera Photos
Screen
The screen on the P10000 Has a ratio of 18:9 and a resolution of 2160 x 1080 and DPI of 403 making it easy to view all screen content. It has a screen bezel of 3mm of what you don't even notice as the screen display is so good.
Battery
Wow wow wow I'm on the 4th day now and its showing 29% (Easy another days use of of this beast maybe two)The phone charges in 3 hours from flat using the charger that comes with the device.
I managed to get 6 days from the battery from the first charge
Video Review
Specification:
Brand: Blackview
Language: English, Russian, German, French, Spanish, Polish, Portuguese, Italian, Norwegian
OS: Android 7.1
Service Provider: Unlocked
SIM Card Slot: Dual SIM,Dual Standby
SIM Card Type: Dual Nano SIM
Type: 4G Phablet
Hardware
CPU: MTK6763
Cores: 2.0GHz,Octa Core
External Memory: TF card up to 32GB (not included)
RAM: 4GB RAM
ROM: 64GB
Network
2G: GSM 1800MHz,GSM 1900MHz,GSM 850MHz,GSM 900MHz
3G: WCDMA B1 2100MHz,WCDMA B8 900MHz
Network type: FDD-LTE,GSM,WCDMA
WIFI: 802.11b/g/n wireless internet
Wireless Connectivity: 3G,4G,Bluetooth,GPS,GSM,Wi-Fi
4G LTE: FDD B1 2100MHz,FDD B20 800MHz,FDD B3 1800MHz,FDD B7 2600MHz,FDD B8 900MHz
Display
Screen resolution: 2160 x 1080
Screen size: 6.0 inch
Screen type: IPS
Camera
Back-camera: 16.0MP + 0.3MP
Camera type: Dual Rear Cameras + Dual Front Cameras
Front camera: 13.0MP + 0.3MP
Video recording: Yes
Media Formats
Music format: APE,FLAC
Video format: 3GP,MKV,MOV,MP4
Other Features
Additional Features: 3G,4G,Alarm,Bluetooth,Browser,Calculator,Calendar, Camera,E-book,FM,GPS,Gravity Sensing System,MP4,Notification,OTG,Proximity Sensing,Wi-Fi
Bluetooth Version: V4.1
FM radio: Yes
Google Play Store: Yes
I/O Interface: 2 x Nano SIM Slot,3.5mm Audio Out Port,Microphone,Speaker,TF/Micro SD Card Slot,Type-C
OTG : Yes
Sensor: Geomagnetic Sensor,Gravity Sensor,Gyroscope,Proximity Sensor
Battery
Battery Capacity (mAh): 11000mAh
Battery Type: Non-removable
Dimensions and Weight
Package size: 21.50 x 21.50 x 5.20 cm / 8.46 x 8.46 x 2.05 inches
Package weight: 0.7750 kg
Product size: 16.50 x 7.70 x 1.46 cm / 6.5 x 3.03 x 0.57 inches
Product weight: 0.2930 kg
Unboxing video
Conclusion
Is this phone worth the cash,Yes it sure is and that's not just me saying that iv let some of my friends have a play and there thoughts are much the same as mine, Yes a big phone but it does everything so well, great for surfing the web with its vivid screen and not have to worry about the battery running flat. What has surprised me is that the ladies like it too had some great feedback wow its so big lol
Package Contents
Back Case
Cell Phone
Earphones
Earphones Adapter
English Manual
OTG Cable
Power Adapter
Screen Protector
SIM Needle
Type C USB Cable
More of Blackview products can be found here
The lastest being the Bv9500 pro on indiegogo
