MX9 PRO RK3328 reset button?
Originally posted by mikk View PostThe tv knows the box is connected but nothing happens with reset button pressed while power is applied. The lights are ok changing from red to blue, is there another way to revive it?
dont press to long , short Time , then stop & wait , do you know a Recovery is installed ???
greetings / gefattern
Hi ,
first discribe once what exactly happend with your Box , what kind of TV do u use , FullHD or 4K ,
Pictures of the PCB , both sides , nearby , good light would be good too ,
i think you have no Recovery installed , if u want to unbrick u must flash a new Rom , do you have
the Stockrom or any working one .
greetings gefattern
There are currently 1606 users online. 0 members and 1606 guests.
