Type: TV Box GPU: Mali-450MPCS CPU: RK3328 Core: Quad Core RAM: 4G RAM Type: DDR3 ROM: 16G Max. Extended Capacity: 64G |
Decoder Format: H.265 Video format: 4K Audio format: AAC,FLAC,OGG,RM,WMA Photo Format: BMP,JPEG Support 5.1 Surround Sound Output: Yes |
5G WiFi: No WIFI: 802.11b/g/n Bluetooth: Bluetooth4.0 Power Supply: Charge Adapter Interface: DC Power Port Antenna: Yes Camera: Without Language: Multi-language HDMI Version: 2.0 Other Functions: 3D Games,3D Video,DLNA,Miracast,PAL HDMI Function: HDCP |
System Bit: 64Bit |
Power Type: External Power Adapter Mode |
Remote Controller Battery: 2 x AAA Battery ( not included ) |
Product weight: 0.1100 kg Package weight: 0.3800 kg Product size (L x W x H): 12.00 x 12.00 x 2.20 cm / 4.72 x 4.72 x 0.87 inches Package size (L x W x H): 16.00 x 13.00 x 11.00 cm / 6.3 x 5.12 x 4.33 inches |
Package Contents: 1 x TV Box, 1 x English User Manual, 1 x Power Adapter, 1 x HDMI Cable, 1 x Remote Control |
V8802 TV Box Support 4K H.265 - Rockchip 3328 A7.1 4GB RAM + 16GB ROM 802.11b/g/n WiFi USB3 GiG lan BT4
V8802 TV Box Support 4K H.265 Rockchip 3328 Android 7.1 4GB RAM + 16GB ROM 802.11b/g/n WiFi USB3.0 1000Mbps BT4.0
Specification
Tags: None
There are currently 2623 users online. 1 members and 2622 guests.
