A95X PRO Google Android 7.1 TV BOX Hard Bricked
    i need help i have an android box A95X Pro
    i installed Super SU and it bricked the box
    I tried to flash it with a firmware of A95x and it bricked everything
    now I can no longer use memory card recovery the red LED is still present and the blue led is gone !!!
    I can not connect it to the PC with a USB and USB_Burning_Tool I am running Windows 10 and USB_Burning_Tool 2.1.6
    I think I lost the recovery mode from Sd card
    I think it is necessary to short circuit one of the chips in the motherboard to be recognized again by USB_Burning_Tool but I do not know which chip is the right one and which pins must be shortcircuited
    thank you in advance any help is always welcome
    Image IMG 20180629 184904 hosted in imgbb.com
    You are depressing the "reset" button inside the AV hole, correct???
      Yes of course
      I try to connect the box to the PC by USB cable i press reset button but it did not work
      Image 2018 06 29 194849 hosted in imgbb.com
        I press and hold the button for ten or fifteen seconds but it does not work
        Windows says it's unrecognized device
        there is nothing in USB_Burning_Tool
        Image IMG 20180629 195316 hosted in imgbb.com
        • trebor
          trebor commented
          Editing a comment
          Sounds like a driver issue,
          Remove device from windows device manager,
          Then let it refind itself
          or uninstall/reinstall USB driver
        I uninstall and reinstall but it does not work
        Image 2018 06 29 202009 hosted in imgbb.com
          good news it works after several attempts
          it works
          I need the right firmware for this box please
          and the right setting for the USB_Burning_Tool
          Image 2018 06 29 205135 hosted in imgbb.com
            I tested the firmware of atvXperience v2B
            and it gives me this error
            I do not know what to do anymore
            Image 2018 06 29 222119 hosted in imgbb.com
              after several tries it worked
              you have to set the temperature between 20 and 40
              and we also need the adapter cable 5v
              and re-pay several times
              I used this firmware
              atvxperience.com ist die beste Quelle für alle Informationen die Sie suchen. Von allgemeinen Themen bis hin zu speziellen Sachverhalten, finden Sie auf atvxperience.com alles. Wir hoffen, dass Sie hier das Gesuchte finden!
              atvXperience v2B - For Joe Public
              waiting for a better firmware
              thank you very much for everything
                That is a nice firmware, but it will not recognize the Widevine Level 1 right now. NayamAmarshe, the author of this firmware has one of these boxes on order. When he gets his box, he will get the Widevine working again......... Your Widevine Level 1 is not gone, just hiding until the firmware can access it.
                Edit: Glad you got your box working again. Most of all, you now, know what it takes to get your computer to "see" it......
                  Yes Fortunately
                  it is a great firmware
                  I am happy
                  thanks a lot NayamAmarshe
                    Good evening
                    so I come back with this question that created the problem in my box at the beginning
                    How can i get Root acces
                    with atvXperience v2B ???
                      Good evening
                      Give this a try. You have to use TWRP to install it. Get the TWRP from ATVXperience website.
                        how do I install TWRP in my machine?
                          Go to his website and download TWRP 311 (https://www.atvxperience.com/downloads/#link_tab-tools). Copy that file onto the root of a microSD card or USB pen drive. Insert the micorSD card OR pen drive into your box. Power off your box, and with a round tooth pick or paper clip, stick the tooth pick into the AV hole on the back of the box and gently press the switch inside the hole. You can hear it and feel it click. While holding the switch depressed with the tooth pick, plug back in the power plug. Count to 10 and release the tooth pick. It will boot into Android Recovery.
                          After you reboot with the reset button depressed, you should open the Android Recover screen. You selections will be in blue. Select "Apply update from ext". From there select SD card.
ID:	734295Click image for larger version
                            I can not access to Android Recover screen ...
                            it boot directly to ATV Xperience
                            I am depressing the reset button and holding it, then I plug the power back
                            but i it boot directly to ATV Xperience
