[SOLVED] XGODY CSA93 3GB/32GB unbrick
    Hello,
    i brick my CSA93 TV Box.
    Anybody know which Pins to short ????
    I uploaded some Pick's.
    Please help me
    HD :
    http://www.bilder-upload.eu/show.php...1530423117.jpg
    http://www.bilder-upload.eu/show.php...1530423154.jpg
    I hope not under the passively cooler !!
    Thanks to anybody how can help. Click image for larger version  Name:	photo_2018-07-01_07-18-59.jpg Views:	1 Size:	181.4 KB ID:	733784Click image for larger version  Name:	photo_2018-07-01_07-19-22.jpg Views:	1 Size:	170.6 KB ID:	733785
    Hi ,
    do you see the Skyhynix Chip beside the USB port , top solder row ,
    right side small triangle , from there u have to beginn with counting ,
    try 7-8 / 8-9 , not sure which u must use , but if u try one by one , i will
    be sure u will find the right one !!! , good luck / gefattern
      .... YES !
      You be the MAN ! ^^, Thanks a lot !
      It was Pin 7-8,
      to anybody with the same problem:
      Put the AC/DC and the USB Cable into your pc.
      If you dont put the AC/DC in, your flash will be abort !
      If you can't flash any Stock ROM, try the ROM further down.
      Sorry for my bad english, i'm from germany .
      The Stock ROM for the CSA93 3GB/32GB DDR4 x64 comes with Android 6.1.
      Try this ROM:
      -------> Name: aml_7.1.2_s912_q9377-H96PROPLUS_mac-20171129_Shonk.7z
      -------> Path: https://mega.nz/#F!8qhRRaYJ!2ZA3VLjv...TF27g!pjRnUKBK
      This ROM is with:
      - Android 7.1.2
      - working Clock,
      - stable WIFI (!!!),
      - HDMI CEC,
      - Generic Keymap Fix (key 28 = Enter #DPAD_CENTER) <----- If your USB/Bluetooth keyboard makes problems
      - no problems to install Nova Prime 5.5.4 / SquareHome 2 Premium v1.7.5
      - ect....^^
      http://www.bilder-upload.eu/show.php...1530461387.jpg
        I bricked my csa93 box too. Thanks for the info to short this box!
          Thanks for the nice Images! Does any image in the repository work for CSA93 and are you sure about DDR4? Mine says DDR3. Did someone try Armbian on this device?
