[SOLVED] H96 Max DMYCO Box - MXR PRO PLUS Inside - Looking for ROM
    So I got another box, it looks like a H96 H2 MAX but the inside looks more like a clone.
    Photos attached!
    Board: MXQ_RK3328_D4_V1.2
    Rockhip RK3328
    Wifi: HS2734A
    eMMC H26M64208EMR
    32GB, 4GB RAM DDR3
    Does anyone knows of a working ROM for this device?
    The ROM that is supposed to be the "original" one is the:
    H96 MAX H2 RK3328 20180314
    Wifi not working and two cores are completely disabled!
    You may only view thumbnails in this gallery. This gallery has 5 photos.
    MXR PRO Firmware rk3328_d4_rtl8723_20170919_r1(mxrpro 20170921).rar
    Runs REALLY fast and stable! (4 cores working)
    Bluetooth and Wireless don't work but I don't need either of them for now (LAN connection).
    Still looking for the correct firmware for this box, for now I'l stay with this one!
      Ok so this is DEFINITIVELY a MXR PRO PLUS inside a.. kind of H96 MAX box... with a different Wifi chip apparently (HS2734A).
      Am going to try another firmware "MXR PRO PLUS_RK3328_25012018_AndroidPC_es.zip" found here.
      Will keep you all updated!
        I can confirm this is definitively a MXR PRO PLUS, the ROM works perfectly (kind of), bluetooth works, WIFI shows all AP's but can't connect (acts as password is always wrong). 4 Cores working and it's stable.
        I may end up trying to do a decent ROM for this device, for now the only complain I have for this rom is that it comes with a weird "Superuser" root app instead of the SuperSu root app.
        -- Edit: Using a modified ROM based on the one by mo123, works flawlessly (except for the WIFI problem)
