QINTEX R33 TV STICK ANDROID DEVICE
    Greetings,
    Today we got a new Review for you. This Time it is for the
    QINTEX R33 TV Stick.
    It is a new Device from the
    QINTEX Company a small device which is based on the SoC Quad Core Rockchip RK3328.
    In its configuration, it basically highlights its external antenna on the rest of specifications that are within the average that
    we find in the equipment with this SoC.
    SPECIFICATIONS:
    Model QINTEX R33
    CPU RK33
    CPU MALI 450-MP2
    OS ANDROID 7.1.2
    RAM 2GB
    STORAGE 16GB
    WIFI WiFi ac – 2.4/5 GHz
    BLUETOOTH 4.0
    PORTS 1x USB 3.0
    microSD reader
    HDMI 2.0a
    microUSB OTG
    microUSB charge
    CONTENT:
    The Device comes packed in a cardboard box.
    Inside we find the Device extender HDMI Cable Micro USB Cable and the Power Adapter.
    Product Details:
    The Housing of the Qintex R33 is made of plastic and we have a hood that covers the HDMI 2.0a connector.
    It has a nice haptic and feels not cheap.
    On one side we have the small Wifi antenna that we can rotate to put it vertically.
    Also we have a mini SD-CARD Slot a Micro USB Port and the Micro USB Power Port.
    The best of it is the USB3 Port on the back of the Device. There you can connect an external Hard Drive to Stream your Movies from.
    Power Up the QINTEX R33:
    After the Power Up of the Device, we have a launcher based on squares where we have access to Google Play, Kodi, browser,
    settings and different subcategories.
    In the lower part, we have a row where we can add optional shortcuts with our apps. We can change the default launcher by installing another.
    The resolution of the system is after the Fimrware Update over OTA FullHD.
    As we have verified, we have a navigation bar and notification bar that automatically hides perfectly, something that is practical
    if we want to use a mouse to manage the system, for example.
    In the installed applications of series are the classic ones, we have Wifi display and Happycast that allows us to share the screen of our mobile,
    RKMC (Kodi), Chrome, File Explorer, wireless update to update and Youtube in Android TV version.
    Experience:
    The Qintex R33 TV-Stick runs fast and responsible with Android thanks to the Rockchip RK3328 Quad Core processor.
    It´s GUI runs in FullHD Mode that we do not see every Day on that Devices.
    2GB of Ram give you enough Power for Multitasking. We test Netflix and Amazon Prime also YouTube Streaming without any Problems.
    The best of it supports HDMI-CEC.
    Google Play Store works out of the Box and you can install the most common Apps without any Problem.
    The Device is rooted out of the Box.
    Some Benchmarks:
    We run the usual Antutu Benchmark with an overall Score of 34600 Points.
    Meanwhile, the Device runs Warm but not hot.
    Also, you can play some easy Games on it.
    Conclusion:
    PRO CONS
    Compact 2.4 GHz Wifi slow
    ANDROID 7.1 Gets Warm
    USB 3
    Support 5Ghz Wifi
    You can Buy it here:
    https://es.aliexpress.com/store/prod...73987971VxEqOz
