EgoIggo S12Pro - system update?
    Hello Team,
    I've bought few year ago on Amazon the TV box below:
    All work as expected however, since long time I do not have any system update.
    I suppose that the vendor as left but not sure.
    My questions are:
    Based on specs below,
    How to upgrade to latest version of Android?
    What firmware is the most compatible with my hardware specs?
    Thanks for your help,
    Amazon product ref: https://www.amazon.fr/EgoIggo-Androi.../dp/B01N3OTFKA
    EgoIggo.
    System configuration:
    CPU: Amlogic S912 Octa core ARM Cortex-A53 CPU jusqu'à 2GHz
    GPU: ARM Mali-T820MP3 GPU up to 750MHz
    RAM: 2G DDRIII
    ROM: 32G eMMC
    Power:
    DC 5V/2A
    Indicateur d'alimentation (LED): Bleu(en marche) , rouge(arrêt ou veille)
    Specs :
    Matériel: Plastique
    OS: Android 6.0
    WIFI: QCA 9377 2.4G +5G+5G ac +Bluetooth4.1
    Support 3D: oui
    Formats d'encodage supportés : HD MPEG1/2/4,H.264, HD AVC/VC-1,RM/RMVB,Xvid/DivX3/4/5/6 ,RealVideo8/9/10
    Système de fichiers supportés: FAT16/FAT32/NTFS
    Format de sous titres supportés : SRT/SMI/SUB/SSA/IDX+USB
    Sorties video: SD/HD max.1920x1080 pixel
    OSD Langue de l'interface:: Français/Anglais/ Allemand/ Espagnol/Italien et bien d'autres
    LAN/Ethernet: 100/1000M, standard RJ-45
    Wireless: Établit en WiFi
    Mini Clavier sans fil : Clavier Qwerty avec surface tactile, Dongle USB
    HD: HD 2.0 up to 4k2k Output
    4K2k hd décodage: 4k2k H.265 Hardware Vidéo Decode et 4k2k Output
    1080P/AV/Dolby/3G: Support
    SPDIF/IEC958: Coaxial(Optical)
