After launch the application with administrator rights, select your micro SD card as removable disk to be used, tick ‘To partition and Format’, then Click ‘Open’ and choose u-boot.bin from your device stock firmware package. Now press ‘Make’ button and when it’s done just copy all the firmware files to micro SD card (aml_autoscript, factory_update_param.aml, firmware.zip, recovery.img, u-boot.bin, unlock_autoscript).
