My H96 MAX 4K RK3328 just worked for 20 days only, and seems to have bricked. There is this "BOOT" displayed when it is plugged in. I tried to Upgrade through "Factory Tool 1.45" with ROM provided by the seller @ Aliexpress, But I am getting this "Download IDB Fail" message. Image attached. Please help me in this.
**HELP** My H96 MAX RK3328 seems to have BRICKED - Help Unbrick the same
I am a kind of newbie,and it is great to be a part of this thriving forum for TV Boxes, which hitherto unknown to me.
My H96 MAX 4K RK3328 just worked for 20 days only, and seems to have bricked. There is this "BOOT" displayed when it is plugged in. I tried to Upgrade through "Factory Tool 1.45" with ROM provided by the seller @ Aliexpress, But I am getting this "Download IDB Fail" message. Image attached. Please help me in this.Tags: None
Originally posted by ganesh2k5 View PostI am a kind of newbie,and it is great to be a part of this thriving forum for TV Boxes, which hitherto unknown to me.
Originally posted by Mywk View Post
All those H96 MAX RK3328 giving problems seems to be somewhat common now, got two, one came faulty, the other one has a faulty WiFi chip and had to end up porting a ROM for it because it's a clone after all.. Do you have a photo of your board? There are a few variants of this "H96 MAX RK3328" (Inside the box, just remove the rubber pads and unscrew the screws, do it disconnected from power and be careful as the WiFi antenna is usually glued to the box, take a photo of both sides and if you can write the number of the "biggest" ICs (parts) here).You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
ganesh2k5 Looks like my old one that came defective (worked 2 days then puff), it should have on the box "MXQ_RK3328_D4 V1.2".
1- What ROM are you trying to install? Use the correct one, this is important.
2- Use Factory Tool v 1.61 from here.
3- Try to flash in MASKROM instead, see the image attached (red circle), you have to short those two pins then it should show up in Factory Tool as MASKROM instead of Loader.
4- If you get it running, this box is missing a heat sink, either add a heat sink or add a fan to the place I marked in the image attached (yellow circle).
Best of luck!
Originally posted by Mywk View Postganesh2k5 Looks like my old one that came defective (worked 2 days then puff), it should have on the box "MXQ_RK3328_D4 V1.2".
Best of luck!
Thanks for your guidance, fortunately seller from the Aliexpress has agreed to replace this box.
Can you suggest me which chipset/brand will be better and stable? Because I am totally confused with the numerous brands/Chips/ configurations to choose from.
Basically I need a stable futuristic TV BOX around US$ 100.
Thanks again for your helpful insight.
Originally posted by ganesh2k5 View PostThanks for your guidance, fortunately seller from the Aliexpress has agreed to replace this box.
what are your needs ??? for the S905W are some good Roms available ,
for sure take a Box with Rom support , good luck
gefattern
Hello, I have the H96 max box, I made the short circuit as in the photo above, but the rom does not install, its brand nonstop idb fail and the other I do not remember more. my H96 is blocked in MASKROM mode, how can I do this? or you find the NAND FLASH for short circuiter?Last edited by viruskail; 25 March 2020, 18:31.
There are currently 2366 users online. 3 members and 2363 guests.
