R-TV BOX PRO AMLOGIC S912 4K TV BOX FIRMWARE UPDATE 20171222
    Hey guys,
    Glad to share the firmware for R-TV BOX Pro 4K TV Box
    PC Flash Firmware
    Flash guide, please refer to: http://blog.geekbuying.com/index.php...utorials-tool/
    Have fun!
    This firmware update bricked my R-TV Box Pro device. Dear Geekbuying support this update is not compatible with the R-TV Box Pro 3GB 16GB device. It is bricked and I only see a b lack screen now.
    I dont know what is the correct factory firmware to flash it back. Please advise where I can download the previous factory firmware so I can recover it. I have used the usb burning tool and the programming is sucessful but box has no screen anymore.
      Can someone please suggest me a suitable firmware to recover my box. I tried the H96Pro + and it works but it crashes alot. Please help find the correct frimware for R-TV Box Pro.
        hello friend,please kindly tell me when did you buy this item?
          I have the same problem. It is interesting that the motherboard has such markings: S912-k-s10 DDR4. In that case, it should fit the software from the R-tv box s10. I use USB burning tool for flashing 2.1.6. Each time at 4% I get an error. One time I managed to go through the flashing process to the end but after connecting to the tv nothing happened. The box kept shining with the blue light on the casing and nothing was showing on the screen. There was no signal. I do not know what to do anymore. Maybe the short pin method would somehow help here. But I do not know which pins to close
              Hello, one year ago.
                Edit: just delete
                  Sorry for late response. Could you please tell what shows on screen when get an error."Each time at 4% I get an error." Or you can send me a picture.help to get more info.
                    Hello,
                    If I connect my tv box without pressing the reset button, I get something like that
                    Click image for larger version  Name:	menadzer urzadzen.PNG Views:	1 Size:	46.9 KB ID:	746569
                    after running the USB Burning Tool shows that it has been connected correctly so it loads the * .img file and I press start
                    Click image for larger version  Name:	usb burning tool2.PNG Views:	1 Size:	53.8 KB ID:	746570
                    this is the log file:
                    [22:17:50 741][HUB5-4][Inf]--CloneImageProxy
                    [22:17:50 741][Global][Inf]--OpenImg C:\Program Files (x86)\Amlogic\USB_Burning_Tool\upgrade.img
                    [22:17:50 771][HUB5-4][Inf]--Connect path=Intel(R) ICH8 Family USB2 Enhanced Host Controller - 283A/P0/P3
                    [22:17:50 771][HUB5-4][Inf]--Start burning...
                    [22:17:50 841][HUB5-4][Inf]--------------ERASE BOOTLOADER------------
                    [22:17:51 371][HUB5-4][Inf]--2-2-0-0
                    [22:17:51 390][HUB5-4][Inf]-------------Download DDR.USB-----------
                    [22:17:51 390][HUB5-4][Inf]--2-2-0-0
                    [22:17:51 390][HUB5-4][Inf]--Control write pll reg1 0xd9000000:0x000000b1
                    [22:17:51 901][HUB5-4][Inf]--Control write pll reg1 0xd9000000:0x00005183
                    [22:17:52 407][HUB5-4][Inf]--Control write pll reg1 0xd9000000:0x000000b1
                    [22:17:52 917][HUB5-4][Inf]--Control write pll reg1 0xd9000000:0x00005183
                    [22:17:53 433][HUB5-4][Inf]--Write initial succeed
                    [22:17:53 464][HUB5-4][Inf]--Upload encrypt at 0xc8100228
                    [22:17:53 464][HUB5-4][Inf]--ulValue = 0xadfc318c
                    [22:17:53 464][HUB5-4][Inf]--Read encrypt value succeed
                    [22:17:53 495][HUB5-4][Inf]--Transfer complete
                    [22:17:53 495][HUB5-4][Inf]--Run at address 0xd9000000
                    [22:17:53 495][HUB5-4][Inf]--RunInRam succeed
                    [22:17:53 839][HUB5-4][Inf]--2-2-0-0-0-1-0-0
                    [22:17:53 839][HUB5-4][Inf]--CheckFileRunState succeed
                    [22:17:53 839][HUB5-4][Inf]--runResult:0x 0,paraMagic:0x7856efab
                    [22:17:53 839][HUB5-4][Inf]--ddrCapacity:0x 100
                    [22:17:53 839][HUB5-4][Inf]--ulValue = 0xadfc318c
                    [22:17:53 839][HUB5-4][Inf]--Download UBOOT.USB buffer at 0x0200c000
                    [22:17:54 011][HUB5-4][Inf]--Transfer complete
                    [22:17:54 230][HUB5-4][Inf]--2-2-0-0-0-1-0-0
                    [22:17:54 230][HUB5-4][Inf]--Download DDR.USB buffer at 0xd9000000
                    [22:17:54 230][HUB5-4][Inf]--Transfer complete
                    [22:17:54 230][HUB5-4][Inf]--DownCheckPara succeed
                    [22:17:54 230][HUB5-4][Inf]--Run at address 0xd9000000
                    [22:17:54 276][HUB5-4][Err]--generatedAddSum:0x668dc502;srcAddSum:0x47aa621e;ru nResult:0x e6;paraMagic:0x7856efab
                    [22:17:54 276][HUB5-4][Inf]--ReadCheckPara failed
                    [22:17:54 276][HUB5-4][Inf]--m_iFileIndex:0
                    [22:17:54 386][HUB5-4][Err]--[0x11000902]Unknown
                    [22:17:54 386][HUB5-4][Inf]--Close device handle 0x00000934
                      Hello,
                      Hello friend,thank you for your info.We will check it. Sorry for inconvenience.
                        Hey,
                        I see that nothing is happening. It looks like it is not the best device.
                          Hey,
                          hello friend,please send me a picture of the USB port in the TV BOX.
                          I need to check it and send you another firmware.
                            Hello, this is my device inside
                              Thank you friend,Please send me a picture of USB Port.I need to check the color of USB port.
