OUKITEL K7 Joins Aliexpress Smartphone Week: Flash Sale at $161.59
Name:	OUKITEL K7 smartphone week.jpg
    Since released, OUKITEL K7 has been invited by many stores to do flash sale. This week K7 is engaged in Aliexpress Smartphone Week to do flash sale at $161.59. From July 19th until July 25th, users can get this 10000mAh massive battery smartphone at OUKITEL Global Store on Aliexpress.
    OUKITEL K7 features a 6 inch 18:9 display with 2160x1080 resolution. The AUO brand LCD display shows bright colors with high color saturation. Though 6 inch, K7’s total size is similar size as traditional 5.5 inch smartphones. 18:9 display design makes smartphone easier to hold in one hand and views more contents in one interface. It looks more elegant and sexy.
    K7 is powered by a 10000mAh high density battery, supporting up to 1 week normal use. It packs a 9V/2A quick charger to fully charge the 10000mAh battery in 3 hours and 40 minutes. With 4GB RAM and 64GB ROM, feel free to run and store your loved apps on K7.
    OUKITEL K7 Smartphone Week activity starts on July 19th and ends on July 25th, during which you can buy K7 at $161.59 which is the lowest discount after presale. OUKITEL Global Store also prepares flash sales for other hot sellers of OUKITEL, to know more information, check at OUKITEL Global Store.
    http://oukitel.com/
