MXQ Pro - Reset Button Not Working
Hi all! I’ve got a S905x box that I’m stuck with (MXQ Pro 4K - in Android settings it’s listed as an MXQ Pro II) so I’m trying to get the most of it. It’s sluggish as all get out (1gb/8gb), but I’ve found a new firmware I’d like to try that I’ve found on this site. The problem is, I can’t figure out how to flash it. The AV reset button doesn’t work - I push it in and power on the box, but it just keeps booting to the regular start screen. I tried with the USB burning tool, but since I flashed a different firmware to the box (pretty stock firmware from Chinagadgets), the box won’t get detected by Windows. I’ve read that these problems can maybe be caused by no root, so I tried rooting with a couple of apps, but they fail. Any suggestions of what to try? I checked with a multimeter and the button does appear to have continuity. Am I stuck with what I’ve got now?Tags: None
There are currently 2227 users online. 0 members and 2227 guests.
