Lollipop Minix X6 + Mygica [Roms] Ported to Mxq S805 wifi drivers 8188 or 8189 or 8812 or 8723 W.I.P.
    Thank you Abdual for your work to make this possible!!!! This first rom will be a ported Minix x6 rom. Post two and three contain a flashable zip and a twrp backup!!
    Post 4 will be a Mygica lollipop rom ported to the Mxq but will only be a Twrp backup to many mods to make it work correctly with just the install zip as with the Minix x6 rom wifi drivers will be the same deal read below if you do not have the 8189 chipset
    For boxes not using the 8189 WiFi chip-set download the extra WiFi drivers if yours is in the zip rename it to 8723bs.ko Using Twrp copy it to system/lib then chmod it to 755 thats it. Happy streaming
    Both roms pre rooted
    Tell me which one is fastest and your box specs!!
    Warning as with any rom some things might not work or this could brick your box. Don't try this unless you know how to restore your box with a factory image you have been warned!!
    Both Roms come already set up for the 8189es.ko driver this is the driver my box uses.
    This is the flashable zip stock rom no mods except for bootloader and only works with 8723bs wifi chip. I recommend you download setcpu and make your max setting to the max and governor to interactive i dont know why they release these roms underclocked like this!! This is the rom I started with confirmed to install and boot on a s805 mxq m201 board once it booted i started to highly modify it to work smoothly on my m201 board.
    Rom: Link http://www.mediafire.com/file/6gv5nx...20dude0316.zip
    Twrp to install: Link http://www.mediafire.com/file/t8qozb...-twrp.rar/file
    Bonus wifi drivers http://www.mediafire.com/file/uu63hk...fi+drivers.rar
      This link will be a twrp backup only works with realtek 8189 wifi. I will not be working on this rom any longer anyone that can do better than me feel free. But please give prompts to Abdual and myself for our work Cheers!!
      Twrp backup Link http://www.mediafire.com/file/qwi173...5.1.1-8189.rar
      Twrp to install or use to restore back up : link http://www.mediafire.com/file/t8qozb...-twrp.rar/file
      Misc wifi drivers http://www.mediafire.com/file/uu63hk...fi+drivers.rar
        Edit: http://www.mediafire.com/file/056946...e0316.rar/file
        Edit. I fixed the display gotta play with this and figure out how to make the fix simple. will be posting in a day or two
        link: coming soon
        as with the x6 rom the wifi driver has to be named 8723bs.ko link allready in this thread to all the lollipop wifi drivers i can fin for the Mxq!!
          For Scott M. Updater script to spoof k200 board http://www.mediafire.com/file/du2ugs...cript.rar/file
          put file in\META-INF\com\google\android save zip should install for you good luck!!
            Could we add more wifi driver support for this ROM ?
              what wifi driver do you need?? The lollipop drivers are not easy to find but i can try!! The only other driver i have sorta on hand is the 8188eu
                Was hoping to achieve as many as possible, assuming wifi drivers for lollipop will be different to other android versions as well as say libreelec. I have managed to install your firmware, had to create a backup with TWRP of the firmware already on the box and then swap over the files, which worked.
                  The 8188etv is same as the EU i believe, was one of the more common wifi chips put on these s805 boxes back in the day.
                    OK i'm posting the correct twrp to install the zip there are two versions that i know of.You must be using the smaller one here is the one i use
                    I have to switch back and forth between the two its a real pain in the arse
                    Here are all the lollipop wifi drivers i have found the zip contains 8188eu,8189es,and 8812au the 8723bs driver is already in the zip. I have not figured out how to edit libhardware_legacy.so to use mulitpule drivers so you have to rename the driver your box uses to 8723bs.ko and using twrp copy it to system/lib and after that go back to the file and chmod it to 755. I hope this helps !!
                    Link http://www.mediafire.com/file/uu63hk...ivers.rar/file
                    Scott let me know if this helps
                      no feedback i take it everyone that downloaded is enjoying
                        Hey, sorry not had a chance to test everything out yet, will get around to it soon and post my results Thanks for the hard work
                          I've tested both the minix and mygica on my mxq s805 with firmware 2015/10/22 and so far the minix is the fastest to boot and runs pretty well, the mygica takes a long time to boot but when it does everything works just sluggish. I do apply the cpu overclock on both with no-frills to 1.25ghz to both, could you debloat the mygica maybe that will help. Thanks for the great roms.
                            Ill look into it
                              Hi I would loke to manage remote control. At the moment I can use only mouse. thanks
