Remote codes for H96 pro +
    I have a H96 pro android box and a Samsung Smart TV with their great ONE remote which controls many devices that are connected to the TV out of the box.
    Detected and controls PS3, WDTV media box, DVD player.
    I have searched the net for the remote codes for the H96 to determine what consumer product might be nearest fit to be able to control the H96 as well.
    Can anyone assist.
    Samsung have thousands of OEM codes embedded, however need to know which OEM product applies to H96. Thank you
    Can anyone assist.
    You need to check your remote, if is a learning remote... If not, you need to find one that is.
      Hi, thanks for feedback. The samsung remote is not a learning remote (it is however simply the most effective product I have laid my hands on).
      It is embedded with thousands of manufacturer device CODES, however it is important to know what the standard H96 codes are based on.
      I have scoured the Net and I believe the codes are based on NEC protocols however I need to assign/select the device and model number for a specific device for it to work,
      I have randomly tried a couple but not luck yet.
      More help please. Has anyone got contact details for the Box manufacturer.
      Thank you again.
        Samsung remote supports only devices chosen by them. It won;t support ALL devices available on the market. H96 is Chinese "shit", at least for Samsung. To unimportant to bother, so it's not supported. It probably only supports Apple TV and MiBox.
        ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
