thanks
no nand chip on motherboard android box
I have a tobux t11 the chipset inside is coming up as mxqpro but it isnt, I am trying the pin short method but the box dosn't have anything that looks like a nand chip, is there anything I can do?
thanksYou may only view thumbnails in this gallery. This gallery has 1 photos.1 PhotoTags: None
Originally posted by loojnkns View PostI have a tobux t11 the chipset inside is coming up as mxqpro but it isnt, I am trying the pin short method but the box dosn't have anything that looks like a nand chip, is there anything I can do?
thanks
the Nand is the one beside the SDCard Slot , please post a good Picture of the other side
of PCB , a MXQPro is only another Box no Chipset , i think u have a MXQPro branded as
Tobox T11 , or whatever your Box is called , important is what CPU/GPU/Wifichip your
PCB has , to look for a working ROM , so please some more Pictures of both sides of
the PCB , nearby good light , not all PCBs have this soldered Pins on Nand , some Boxes
must be shorten another Way ,
greetings / gefattern
Thanks for helping,
sticker on board says G9CX_2_VO.95
printed on board says G9sx_VO.96 2016/11/23
amalogic chip says S905X
chip on the back of the board says 6RP47DgSHd
samsung chip says 640 kcm86rwepD-b031
I think this is the chipset CPU:Amlogic S802 Quad core ARM Cortex A9 2.0GHz
GPU: Octo-core Mali-450MP GPU @ 600MHz
You may only view thumbnails in this gallery. This gallery has 5 photos.5 Photos
you must look under Heatsink , if you not sure , between S802 & S905X is a difference ,
watch this and burning tool link is below video
you need the s905x image file
burn image usb male to male with your pc
you have to load image start then plug in cable whilst holding the rest button for a second
image file can be found here
tonbux t11 is the m9cmax
good website is mxq project
There are currently 2079 users online. 1 members and 2078 guests.
