Bqeel [Android 7.1/2GB/16GB EMMC] K12 S912 Android 7.1 4K tv Box Octa core A53 Processor Dual-Band 5G/2.4G Wi/Fi
    Hi All,
    I have the box below:
    Can anyone suggest the correct rom/firmware to use on this TV box please?
    It's stuck in recovery mode at the moment and I cant find the correct rom
    Thanks for the help,
    sean
    Open the box have a look at what it has Wifi/Ram...
    You will find something compatible for sure, if not better on Freaktab
      OK thanks I will have a look tonight and post back
        I took these pictures of the board inside, not sure which is Wi-Fi and RAM though
          some of the chip letters:
          fn-link 8223a-sr c100151743
          issec 216 hck0k4B4G0446B
          1533kae thg8mfg7c2l8ail k90117 japan (2xug7akw)
          Could this me the model number: mini m8s-706 no-c
            Pretty much yes,
            Just have a look around I am sure you will find something that will fit
              Hello,
              Have you found the firmware ?
              Thanks,
                I have this box. Try the Beelink GT1 firmware for serial numbers that start with s912 and g912. 708NO is the version i am using. The mini m8s firmware will probably work also.
