Android TV (7.1.2) Beelink GT1 port (Mini M8S Pro-C)
    Hi Everyone,
    Just wanted to share a rom I ported to the Mini M8S Pro-C variant (100mbps lan).
    All credits go to tillaz87 for creating this great ROM for the Beelink GT1 (http://freaktab.com/forum/tv-player-...ndard-ultimate)
    I simply just modified it to work on the Mini M8S Pro-C (bootloader, dtb etc)
    Here's the url to download rom https://mega.nz/#!pXYQlI5S!5LRO7AGvK...wQkebuHlsEVbR4
    Amlogic burning tool or bootcard maker is needed to install this rom.
    I only have black screen. My model is 3gb/32.
      If that firmware don't work, the best firmware is the Russian AM3 , or for ATV MULTI_Z6BASED_ATV10.7_Discontinued.img
        Sounds like you have the Mini M8s Pro not the C variant, as far as I'm aware any GT1 firmware should work on it without any modifications.
          Thanks, i will try it.
            I put the GT1_708D0 firmware, and it works for me.
              Thank you very much anthony96. I recently uploaded the 708no-c firmware, Can I overwrite the firmware you uploaded? Or is there a separate firmware for the base?
                Its not based on Beelink firmware, its using Vorke base.
                  This firmware is great, android tv from xiaomi mi box 3 which i have... Everything is great, except 2 of the most needed streaming apps dont work... Amazon prime video for androidTV or nvidia shield & netflix for androidTV... Amazon keeps trying to load vdo & fails... Netflix says at startup that it cant connect to nf server... I planned to keep this fw but alas!!!
                    hi, the firmware works to me, but I can't install any app from de playstore I just enter and chose an app and click to install and just there is a circle moving and nothing happens just stays there, and the rom is clear just came with youtube app and playstore, there's no any file manager app to install apps with a pendrive or sd card, I'm new in this things, can someone help me?
                      04-13-2020, 07:33
                      Hello,
                      Thanks for this.
                      I tried many firmware without real sucess in terms of result.
                      With this my box is fluid and smooth.
                      Just 1 think doesn't wrok properly (but I had naver try that before with other firmware even the original) : song by bleutooth.
                      The song is not proper. Maybe you have an idea to solve that ?
                      Edit 1 :
                      I discover another problem. I can turn on my box with the remote control. I explain me.
                      When box are on sleeping mode, I can turn on my box with remote controle.
                      But when is totally shutdown, I cannot turn on.
                      Somebody have an idea ?
                      One more many thanks for your sharing.
                      Rudy.
                        Hi Rudy,
                        can you please share me the link of the most recent version of custom rom for M8S pro c mini android box. It will be great. Also, you can email me the same on [email protected]
