I have had my H96 MAX box now for perhaps 8-months.
I know how to flash ROMs, TWRP, Titanium Backup & Restore and all of that. I've done it more times than I would like.
But no matter what I do to flash my H96 MAX box, it invariably hangs somewhere (after I tried to boot it), but differs on where it hangs each time.
I gave up on the box for several months, then checked back here to see if a new ROM was released,
There was, so I tried once more today. No luck
Here's what I've done and used ...
I have tried these ROMs:
rk3399_7.1_hcy_stb_ap6255_170721.img
rk3399_7.1_new_H96max_P_A_E_1.5M648M_ear_180102.im g
rk3399_H96_4+32G_max_170526.img
rk3399_H96max_7.1_v1.2.0_power_180502.img <--------- I tried this one today.
I have tried these Batch (burning) tool revisions.
Both work fine (they burn successfully). However during my troubleshooting, I just want to mention that I burned
using both "UPGRADE" and "RESTORE" modes, just in case. It made no difference, but I wanted to try it.
RKBatchTool-v1.45e
RKBatchTool-v1.8e
I also have:
-- Performed a factory reset, wipe, format (etc, etc, etc) while booted into recovery BEFORE burning ROMs (just to start clean).
-- Used the Windows DriverAssitant_v4.5. My MS-Windows has no problems recognizing the device.
In the end, no matter what combination of things I try, the box will hang somewhere:
-- On the initial H96 MAX banner logo
-- On the second H96 MAX banner logo (smaller version that appears after the initial larger one)
-- On the screen that has moving O-rings and says "Erasing"
-- On the "Application Initialization" screen. I only got that far once! Most of the times it hands in the H96 MAX logo
-- etc
Am I missing something here? I'm about to toss this box out. (._.)
Any suggestions would be appreciated.
Thank you.
EDIT1: Above, RKBatchTool-v1.45e should instead read, Factory Tool v1.45
