X92 s912 brick?
    X92 s912 brick?
    Hello
    bought new X92, try to burn new rom (because the missing status bar), i guess something went wrong cause now it's stuck on boot screen, and i couldn't get it into recovery (so can't burn other rom).
    Is there anything else to do? Or just dump it...
    Hello,
    You can flash it new from PC.
    All you need is USB Burning Tool and the Firmware in img format.
    Also an USB A to A Cable.
    Neomode
      Originally posted by Effi View Post
      Hello
      You can bring back the status bar by editing the build.prop. I wanted my status bar to hide and remove soft key notification to activate at every boot up on the home screen.
      I think these control them...
      persist.sys.power_on.hide_bar=on
      qemu.hw.mainkeys=1
