ALBOHES V9 MINI Intel PC with Dual-band WiFi
    Description:
    ALBOHES mini PC is a micro computer that is as small as your smartphone or your external hard drive, but just as powerful as a desktop PC. All you need to use a computer is an HDMI-screen and a mouse and / or a keyboard. Work, play a game, turn your television into a smart media center: the ALBOHES mini PC handles it all. The millions of applications at the Windows 10 App store will give you the control ( or fun ) you are looking for.
    Main Features:
    - Highly efficient Apollo Lake N3450 processor: supporting Windows 10 and equipped with advanced 64 bit Intel Apollo Lake N3450 processor ( Quad-core processor, up to 2.2GHz ) , ALBOHES mini PC can decode and transfer your data at a stunning speed. Get it home and experience its ultra-fast performance to get your favorite shows and movies instantly.
    - Support 3840 x 2160 30Hz 4K HD video, which shows you the most vivid video experience.
    - Stunning storage: 4GB RAM + 64GB built-in processor capacity and 128G max extended capacity via SD card ( not included ), all these large capacity allow you to download and save absolutely various of movies, photos or TV series.
    - Super stable and strong connectivity: featuring high performance 2.4G + 5.8G Dual-band WiFi, Bluetooth 4.0, four 3.0 USB ports and 1000Mbps LAN fast internet speed. This ALBOHES mini pc will deliver amazingly smooth data transfer. Say goodbye to the bothering pop out message: unable to connect to the internet.
    - Ultra-low power consumption: this mini PC runs only 24W, more eco-friendly than those heavy desktops that cost 230 - 250W. Just try a simple calculation: there are 20 persons in a company who work 8 hours with a desktop ( 230 - 250W ), and another 20 persons work with the mini PC ( 24W ), WHO would save more electricity?
    - Mute and compact design: this palm-sized mini PC with no-fan design runs quietly, and small enough to fit on the back of the display. ( A mini PC stand is presented ).
    Note:
    Please carefully refer to the user manual before using the product.
    Specifications:
    - Intel CPU: Intel Apollo Lake N3450 Processor
    - Installed RAM: 4GB
    - System Disk: 64GB
    - Support SD Card: 128GB ( not included )
    - Ethernet: 1000 / 100 / 10Mbps LAN
    - WIFI: Intel AC3165 IEEE 802.11a / b / g / n / ac, 2.4G + 5.8G
    - Bluetooth: 4.0
    - Cache: 2GB
    - Instruction Set: 64bit
    - Processor Base Frequency: 1.10GHz
    - Burst Frequency: 2.20GHz
    Specification
    Brand: ALBOHES
    Product weight: 0.2300 kg
    Package weight: 0.6200 kg
    Product size (L x W x H): 12.00 x 12.00 x 2.30 cm / 4.72 x 4.72 x 0.91 inches
    Package size (L x W x H): 14.00 x 13.20 x 8.90 cm / 5.51 x 5.2 x 3.5 inches
    Package Contents: 1 x Mini PC, 1 x Power Adapter, 1 x HDMI Cable, 4 x Screw, 1 x Holder, 1 x User Manual
    Gearbest
    Only $174.44,buy ALBOHES V9 MINI PC with Dual-band WiFi at GearBest Store with free shipping.
