EWEAT R11 Android 6.0.1 2GB/16GB Ultra HD Audiophile 4K Media Player
    EWEAT R11 Android 6.0.1 2GB/16GB Ultra HD Audiophile 4K Media Player With LED Display Daul Band WIFI Bluetooth Gigabit LAN HDMI OUT ESS9038 PRO DAC
    Click image for larger version  Name:	EWEAT-R11-4K-Media-Player.jpg Views:	1 Size:	51.5 KB ID:	737752
    Best in class audio performance
    Eweat R11 is equipped with ESS9038 DACs for Audio. The ESS9038 PRO set a new benchmark for audio excellence with its best-in class 140 dB of dynamic range in a 32-bit ,8-channel DAC. The ES9038PRO SABRE DAC features ESSpatented 32-bit HyperStreamDAC technology, which is responsible for the outstanding clarity and sound stage
    Coaxial/Optical/AES inputs
    For additional convenience and flexibility, the R11 can convert digital signals from cable and satellite boxes, televisions, video game consoles and other digital transports with coaxial and optical digital outputs and AES output to analog. By bypassing the low fidelity, poor quality DAC of traditional computer soundcards, the R11 turns any computer into a high performing multi-media source by utilizing the ES9038PRO DAC
    Dedicated Stereo Output
    The stereo output offers both XLR balanced and RCA single-ended connectors. The balanced output features a true differential signal path all the way from the DAC to the 3-pin XLR connector. By transmitting a pair of differential signals, the balanced output provides better common-mode noise rejection and improves signal quality.
    Headphone Amplifier
    For a more intimate listening experience, headphones can be connected directly to the R11s built-in headphone amplifier. The headphone amplifier is connected directly to the ESS SABRE PRO DAC and offers a unique performance advantage over standalone headphone amplifiers.
    Ultra HD Resolution
    R11 used the Realtek1295 main chipset, powerful decoding capability and supports 4K UHD H.265/10bit and maximum with 400Mbps streams,
    Support HDR10 technical, and the first one developed 23.976,59.94HZ frame-rat auto switch
    Support all 3D formats playback(including MKV MVC 3D),clean picture, appropriate depth, adjustable depth of field and support 3D subtitle
    Specification as found
    General Brand: EWEAT
    Model: R11
    Type: TV BOX
    Hardware OS: Android 6.0.1
    CPU: RTD1295 DD ,ARM CA53X4,
    GPU: ARM Mali-T820 MP3 L2 Cache 1MB
    RAM: 2GB DDR3
    ROM: 16GB eMMC
    Communication WIFI: 2.4/5.8G WiFi, 802.11ac
    Bluetooth: Bluetooth4.0
    LAN: 1000M
    Media Video Container
    RM/RMVB,MPEG1/2/4 Elementary (M1V, M2V, M4V),MPEG1/2 PS (M2P, MPG),MPEG2 Transport Stream (TS, TP, TRP, M2T, M2TS, MTS)
    VOB,AVI, ASF, WMV,Matroska (MKV),MOV (H.264), MP4, RMP4,IFO,DVD-ISO,BD-ISO,MINI BD,BD-9,BD25, RBD, D5, D9, DVD, CD
    FLV,swf/(.swf) *,3GP/.3gp,AVS/(.avs),3D Bluray(DISC/ISO) or Single-File(*.ts/*.m2ts
    Video Decode
    4KP60 10bit/HDR/HDMI 2.0 Tx& Rx/H264 encoder
    VP9 4KP60
    H.265 /HEVC 4K*2K([email protected] High Tier)
    MPEG1,VCD1.0/2.0,SVCD( up to1920*1080@30P/60I or 1280*720@60P)
    HD MPEG2 MP/HL, ISO, IFO, VOB, TS(up to1920*1080@30P/60I or 1280*720@60P)
    HD MPEG4 SP/ASP, Xvid(up to1920*1080@30P/60I or 1280*720@60P)
    H.263(Profile0/3@L70 1080@60P )
    H.264 BP,MP,[email protected], H.264 MVC SHP (maximum 720@30P)
    WMV9,VC-1 AP@L3( up to 1920*1080@30P/60I or 1280*720@60P)
    DivX3/4/5( up to1920*1080@30P/60I or 1280*720@60P)
    XVID SD/HD( up to 1920*1080@30P/60I or 1280*720@60P)
    RM/RMVB 8/9/10( up to 1280*720@30P)
    AVS: Jizhum profile @ level 2.0/ 4.0/ 4.2/ 6.0/ 6.2
    Audio Container
    aac,mp4,m4a,MPEG audio (mp1, mp2, mp3, mpa),wav ,wma,asf,ogg,ape,flac,amr,3ga,ra, rm, rmvb,ram
    Audio Decode
    MPEG I Layer 1/2/3(2-CH) and MPEG II 1/2(Multi-Channel)
    LPCM,ADPCM,FLAC,AAC,ALAC,AMR,WAV,WMA,WMA pro,OGG,AMR,APE
    DTS digital+stereo
    Dolby Digital AC3
    Dolby Digital Plus
    Dolby Digital TrueHD
    RA-cook/RA-Lossless
    Picture Formats: JPEG ,BMP, PNG, GIF, TIFF, Webp(Android)
    HDD format: Support FAT32, NTFS, EXT3, EXT4,HFS
    Subtitle Formats
    MicroDVD (.sub),
    SubRip (.srt),
    Sub Station Alpha (.ssa),
    Sami (.smi)
    VobSub(.idx+.sub)
    Advance SubStation Alpha(.ass)
    Interface AC 110~220V IN
    STEREO AUDIO OUT
    XLR BALANCED STEREO AUDIO OUT
    Optical input
    Coaxial input
    XLR Audio input
    RS232
    Trigger in/output
    USB 3.0 host
    USB 2.0 host x 2
    TYPE-C HOST
    802.11 a/b/g/n,2.4G/5.8 Dual Band WIFI
    10/100M/1000 Ethernet
    IR in/output
    HDMI2.0 input with PVR function
    HDMI2.0 Audio Only output
    HDMI2.0 output
    Optical output
    Coaxial output
    AV output
    6.5mm Headphone Audio output jack
    External SATA port
    Internal 3.5 inch SATA
    Other Features File System: Fat16 / Fat32 / exFAT/NTFS/HFS+/Samba/ext2/3/4
    Subtitle Language: Standard version: simplified Chinese, traditional Chinese, Turkish, Greek, Hebrew, Czech, SE European, Central European, Cyrillic, Western, UTF8
    Menu Language: Standard version: simplified Chinese, traditional Chinese, English, Russian, Spanish, Czech, Dutch, Italian, French, German, Turkish, Hebrew
    System Upgrade: OTA upgrade or USB upgrade
    Video Streaming: HTTP, RTSP
    Dimension&Weight Unit Dimension: 430*310*72MM
    Unit Weight: 7.8kg
    Carton Size: 525*380*195mm
    Carton Weight: 8.5kg
    Package Contents 1* TV BOX
    1* IR remote control
    1* HDMI cable
    1* Power adaptor
    1* Warranty Card
    1* Quick Install Guide
    GEEKBUYING
