Seems though the minor issues as to why some phone apps would fail on the 64 bit, we're due to some missing libs required for 32 bit apps. Will test further with the apps that had issues at a later time.
Missing some odd system libs
As of recent I did a comparison between the latest 05/2018 mini M8S Pro-C 32 bit firmware with my latest 04/2018 factory 64bit firmware for the H96 Pro Plus. Oddly the 64bit firmware system libs had less .so and .ko files. Also it was missing a vendorlib in the vendor libs folder.
Seems though the minor issues as to why some phone apps would fail on the 64 bit, we're due to some missing libs required for 32 bit apps. Will test further with the apps that had issues at a later time.Tags: None
There are currently 3172 users online. 0 members and 3172 guests.
