New Firmware for H96 Max RK3399 (180713)
    guys here is latest firmware for H96Max (180713)
    Cool thank you. I've only downloaded firmware for this box once but I am not sure if we use same tools so I think I better wait for someone more experienced to check first
      added normal link
        Originally posted by JoseM View Post
        added normal link
        has anyone tried it ? Does it actually fix anything or is it another re release of the same broken firmware
          I just hope Display - hdmi - color, settings were all put back in because last firmware they were taken out and video quality was absolutely horrible, even worse than my amlogic boxes.
            Tried it on my H96max AP6255 Wifichip.....quickly...still messing with it....used Factory Tool 1.45....They finally upgraded the Kodi that comes with the firmware to 17.6...I really don't know what is the difference...Amazon Prime finally works!!! The HDMI settings with color brightness settings is there...There is a CEC setting...I don't remember seeing it there before...no Google’s Widevine DRM....I use ethernet...feel fast...I stick with it for a while....
              Originally posted by freakkid View Post
              Cool thanks for info. Real happy amazon video works finally.
              Its good to have the hdmi color, saturation, brightness and tone settings because they make the picture really awesome
              But, could you please check if 'ycbcr444, 8 and 10 bit,' settings are there. There will also be ycbcr422 and rgb settings in same location
              These were taken out of last firmware update and they are necessary for proper video display. They are the most important settings for me
              I do not have a computer so I have to wait for a while to do update at my friends
              Thank you for your help
                no ycbcr444 10 bit settings...they were taken out of the first May update or the May 25th??...don't remember seeing them...also you can now remove apps from recent menu with mouse...now uses stock power menu with Power off and Restart only..
                  Sorry to bug you, will be last question I believe.
                  When you say "no ycbcr444 10 bit settings" do you mean only the 10 bit settings are gone or are the ycbcr444 8 bit settings gone as well?
                  I'm thinking you mean all the "ycbcr" and "rgb" settings are gone like in the May firmware update
                  Thanks for the help. Pretty sure this is all I need to know
                    I mean all ycbcr & rgb settings are gone...I rememember using them on my 4k tv...did not notice difference....made me
                    think they were not working at the time...
                      Oh they work great. My video quality was bad without them when I installed 20180525 firmware. I went back to 20180502 and picture quality was great again.
                      I guess I'll stay on old firmware. Not sure why a good feature was removed. Thanks for your help
                        180713 works great! Does anyone have CEC working?
                          I just updated from 20180502. Initial view is that I cant really see much difference between the 2 - still hasnt got a resolution option to set 4K . Got about 105000 on Antutu latest version so nice and smooth. Anyone got a changelog for this one?
                            Hi has anyone tried Nova Launcher on this new firmware yet ?
                              Tried it. Same as before - doesnt work. App stops - select mediabox
