Amlogic Next7P12-8G Modified Recovery - Stock Rom & Flashable Root
    These files are for the Amlogic Nextbook Next7P-8G commonly sold at Wal Mart.
    Here is what you get:
    Modified Stock 3e Recovery:
    This is the stock recovery, dumped from the device, unpacked, modified to use Google Test Keys instead of Private Nextbook Keys and then repackaged for your enjoyment.
    Unzip and place the uImage_recovery file on your external SD Card. Reboot to recovery by holding Volume and Power. You won't notice any visual changes, but you can attempt to flash any .zip signed with Google Test Keys.
    Your mileage may vary. If something won't flash there is a compatibility problem between the updater-binary or updater-script and our kernel/recovery.
    Download: (Link Removed - No Longer Supported)
    Stock Rom:
    This is a close as I could get to a flashable stock rom.
    This contains a stock bootloader.img, boot.img, uImage_recovery, logo.img, and aml_logo.img dumped from the device. The system partition was also dumped from the device. I believe all of the Nextbook bloatware is here, with nothing added and NO ROOT. Everything has been packaged into an update.zip and signed with Google Test Keys. This WILL reformat System, Data and Cache. Backup any critical data before flashing.
    Place the update.zip on external SD Card and flash using the modified recovery above.
    Root Package:
    This is a flashable .zip that installs the su binary and has been signed with Google Test Keys.
    Put it on your external SD Card and flash it using the modified recovery above. Then install your preference of Superuser.apk or SuperSu.apk from the Google Play store or elsewhere.
    Download: http://www.freak-tab.de/ShaunMT/Kyser_Root-signed.zip
    ROM Version History:
    09-15-2013
    • First Release
    Feedback Thread: http://www.freaktab.com/showthread.php?7012-Amlogic-Next7P12-8G-Modified-Recovery-Stock-Rom-amp-Flashable-Root&p=95740#post95740
    A special thanks to FreakTab user BlackKnight330 for confirming that these files work!
    Enjoy!
    ShaunMT
    Last edited by shaunmt; 20 July 2014, 06:46. Reason: Retired ROM and Recovery Links Removed
    Freaktab Rom Developer
    The ROM and Recovery Above Have Been Retired
    The ROMs and recovery previously linked in the OP above have been retired and are no longer available or supported.
    Please refer to the files below instead:
    See this thread for TWRP recovery:
    http://www.freaktab.com/showthread.php?12618-TWRP-Recovery-with-UBIFS-Support-For-Amlogic-Nextbook-Tablets-(Download-Thread)
    See this thread for new modified ROMs:
    http://www.freaktab.com/showthread.php?11651-ShaunMT-s-Modified-Stock-Based-ROMs-for-Amlogic-Nextbooks-(Download-Thread)
    Thanks!
    ShaunMT
