CORRECTED: No longer needed... Missing lib file needed for Google YouTube TV aka Tube TV (YouTube.unplugged)
    Found an odd lib that is missing in all ATV firmwares that are based on 64bit Android.
    I assume the lib file is in all 7.1.2 32bit firmwares. It's required for Google YouTube TV.
    The lib file name is libcoat.so, and it should be located in libs, or system/vendor/libs
    Please post a link to download if able to upload from your Android 7.1.2 TV box.
    Doing more tests with other streaming apps that fail to run, will add more requests if I find other missing lib files.
    Thank you
    Found that the apk was not arm64 based. Found arm64 variant and fixed the issue.
