I am going nuts trying to open up this box. It runs hot and i want to add some holes. But while i try to pry it open along the edges at the top, nothing unsnaps and i cant find any screws. So please, if anyone know how to open this up, please give a tip. Picture of unit is below. Thanks
Q Plus S912 -- how to open up the box?
Hi all,
Tags: None
Originally posted by trebor View PostI think you will find the top Plastic LID will lift and peel, lotsa sticky stuff take your time.
I have tried to put some holes in to improve the cooling, but it actually seemed to make it worse. Heat gets up to 170F - so I assume that is why it keeps freezing and i need to pull cord to reboot. I have tried just about every firmware i could -- Ugoos seemed to work the best, but that also eventually froze, and unable to turn on box w/ remote using that one.
There are currently 2460 users online. 5 members and 2455 guests.
