I just bought an H96 Pro plus but it may be a knockoff - flash new rom?
    Can I flash a new rom to it?
    The mix between mouse and remote d-pad type navigation is really annoying. I have an air mouse but I believe this is just not a very good rom that it shipped with.
    Can I MOD this thing?
    I see a ton of ROMs here, a dizzying array of hardware models - where do I begin? Is there a HOW-TO sticky that I'm missing?
    I have some decent experience on TWRP/CWM, tablet ROMs over the years (meaning I follow online directions well) but the hardware is always identifiable. This is a different story.
    I bought a H96 Pro Plus off Amazon and the price differences indicated the H96 PPs were not all the same. Mine is here;
    WeChip H96 Pro plus Android 7.1 TV Box 3GB RAM 32GB ROM,Amlogic 912 64 Bits Octo-core Smart TV Box Support Real 4K Dual Band WiFi 2.4GHz/5GHz Bluetooth 4.1 with Remote Control
    WeChip H96 Pro plus Android 7.1 TV Box 3GB RAM 32GB ROM,Amlogic 912 64 Bits Octo-core Smart TV Box Support Real 4K Dual Band WiFi 2.4GHz/5GHz Bluetooth 4.1 with Remote Control: Amazon.ca: Electronics
      I think I landed in a “no question” section of the forum.
        There are lots of threads about H96
        The need to post another new thread on a topic that maybe covered most likely not needed
        Clones or nocks off's as you call it are just made by others maker they may use a different ram, wifi and customise to make it cheaper
        Its still a H96
          Thanks for the reply.
          I cant seem to find any how tos or identification stickies in here. A lot of questions about “what model do I have”, “what rom can I apply”. Is that not where I should start?
          I’ve been told these things are easy to brick. I’m happy to read and prefer not to ask questions if the answer is available.
          Ill keep searching.
