Help Mx9 wired internet problem!
    Good morning, first disclose my English I'm using google translator: / ...
    I have a box MX9, model of the card R329Q_V3.0 2017.09.12, and I installed the rom of Kingbox android 6.0.1 however the wired internet does not work, at first I thought it would be problem on the network card, but searching for other rom's I found a which works the internet wired but rom is modified and very slow, the rom of Kingbox and Leelbox are quite fast and works very well .. I also installed version 7.1.2 of the leelbox and kingbox, but the problem of the wired internet continues. The box does not get IP gets everything 0.0.0.0, does anyone else have this problem and managed to solve it? Does anyone have any solutions please? Thank you everyone's attention
    Hello,
    The problem here could be that the ROM you use has the wrong Driver for your Ethernet Chip.
    Maybe you can try to give the Box an IP Address by Hand.
    Neomode
      Originally posted by neomode View Post
      Hello,
      Neomode
      Hello, thanks for the attention, I already tried to put static IP and it did not work, I tried several rom's and without success too, is there any way to find out which driver is correct for my box?
        Hello,
        Yes there is open up your Box and make an Photo of the Mainboard from both sides.
        Then post it here.
        Neomode
          Hello,
          Then post it here.
          Neomode
ID:	740168Click image for larger version
            I have an Idea.
            Did you have the Orginal Rom and Link to the Custom Rom you want to use?
            I think we have to swap resource.img.
            Neomode
              I have an Idea.
              Neomode
              The original rom I do not have, when I updated I did not backup the factory ROM (dumb), I already researched in this forum and others but I can not find ... But there is a customized rom that the wired network works perfectly, I will pass the link to it, and the rom I'd like to use ...
                I have an Idea.
                Neomode
                Sorry I'm late...
                This is the rom that the network driver works:
                https://mega.nz/#!jYojUATK!8u7QdtWI-...93GQzAHP7zuUvE
                This is one of the rom's that I would like to use (for being faster and having fewer bugs) it can be any of these:
                leelbox android 7.1.2 : https://mega.nz/#!13x3GZDJ!bCma91nQS...k6odHVMJkvnsUU
                Kingbox 6.0.1: http://www.mediafire.com/file/iv355o...0-MV7-1117.img
                  Thank you let's see what I can do..
                  Neomode
                    Neomode
                    Thanks again for your help: D, I'm waiting ...
                      Neomode
                      I found out which network driver on my card is: 8189fs, would it be possible to integrate this driver into .img android 7.1.2?
